Cant see, in my country this video is blocked
Hi Sameer,
use LM3915 for LED Bargraph Display. it is very simple
MANOJ
Hi Manojtm.
I'm waiting for you to send me the files sprint layout for making the boards aud600.
Thank you again.
luizcpimenta@gmail.com
luizcpimenta@yahoo.com.br
Hi Manoj:
Here is the final artwotk of AUD600 ver3.0; will use double sided if EMI makes problem. any suggestion?
It will have OCP, OVP, TP, DC etc controlled by uC.
Raj
Do you like share Files and schematics for uC to diy
If Manoj permits.
Hi Insomnia,
yes with gate resistor 6.8 ohm
MANOJ
Hi Manojtm
Im little confused with Bias AUD 600 Rev 3.0 configuration
my PSU have +/- 80V DC
and +/-12 V DC
want ask.... - Bias connect with - supply rail - 80V DC
+ Bias with +12V DC is this correct ? dont like AUD600 fire with first test
best regards
class d 6000w
My class D stereo amplifier 6000 W rms 2 ohm with smps supply
Do you sale those amps?
how about protections DC OVP HOPS
DC crowbar
Then Balanced Input? limter
hi sameer pls post the pcb files of your smps
>>>>what is your switching frequency in your smps?
>>>>are you using in the 6kwts class d irfp250n as outputs?
>>>>and at what voltage is the class d operating in?
good job highand
good job highand this amp seems good when power is not important but the quality and the cost to own environmental speakers or small
only one question which component is SD
I will try to make this amplifier
soon will expose an amplifier with almost perfect driver
dt adjustable 0.4 ns to 1us
4 amp output + Input to output isolation for low noise need not shift lever
750v works more
8MHz operation until
seems like a dream for Class D amplifiers
greetings and good wishes to all
750v works more
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
