1.5MHz on half vol pot is not narrow band either.Is that considered wideband
So what is the judgement on the audioband frecuency? Normal?
What vol pot value you use? How much is it when at half position? That is in series with the grid and helps answering about the BW measurements.
Salas the line preamp can work with B+ 300VDC or max 310VDC?
I run my cathode follower on 250, it worx. Anodefollower need that and the v-drop over anoderesistor/choke/whatever. Then its a matter of taste. Vgeorge runs lower and is happy I think
Wich gain have your cathode follower?
100 k log that measures 106,6 on 12th step if 21. The relation measures 5,46/100,1.. well in the region
Yes but use 6k8 10w anode resistor.
100 k log that measures 106,6 on twelfed step relation measures 5,46/100,1.. well in the region
How much is it to wiper at half position?
Dang its upside down so it was on 9th step of 21, that why.😱
0,83
curve on pot max is maxing around 840 mV in bass region, slopes down to 703 at 10kHz, and 531 an 20 kHz
Can be enough 5W for 6K8 or what power is necessary?
10W is needed. You can use 2x15K 5W if you already have.
Pot max volume = zero resistance in series to the grid so the BW should be at its max. When pot is at low listening volume the BW should shrink. But never a slope in audio bandwidth across the full rotation.
Thanks!!!!!!!!!!!!!!
- Tubes / Valves
- 6V6 line preamp
