150W MOSFET Amplifier with IRFP250x2
AX12 is so good amp with good quality
i use that in my car with 2 OHM load and + - 30 VDC
i can not find protection for that
i can not use apex protection beacuse it have mor component and i do not need soft start
i want use micro AVR for protection but i must find DCprotect- short circute protect and over curent protect befor that.
i can shutdown my smps converter when amps go to protect mode
i dont like relay
i dont know why but i dont like it
i recommended AX12 to all
any one can help me to creat protection for AX12?
NX-14 in sprint layout format. I only modified AX-14.lay file from "100W Ultimate Fidelity Amplifier" thread.
  • NX - 14.zip
    NX - 14.zip
All NX14 files at one place:
  • New Text Document.txt
I forgot to place zener diode. Here is correct one in image and pdf format. AndrewT I made modification just to place multi-turn trimpot, can u verify this board.
Is IRFP250N OK for NX14 ?
Here (http://www.diyaudio.com/forums/soli...l-interview-bjt-vs-mosfet-77.html#post1206850) I found a related question:
"What's the difference between IRF parts with and without suffix "N"?
For example IRFP250 and IRFP250N." But I couldn't find any answer in the same thread.
A general look at the datasheets tells us that IRFP250N is newer than IRFP250, with lower capacitance figures, among other slightly better measures.
http://www.irf.com/product-info/datasheets/data/irfp250.pdf
http://www.irf.com/product-info/datasheets/data/irfp250n.pdf
That´s my humble opinion.
APEX F100
part list
kom=peace(s)
otpornici:resistors
220k 3kom
1k 6kom
2k2 5kom
100k 1kom
3k3 2kom
15k 1kom
1M 1kom
56k 1kom
100r 2kom
22k 1kom
180r 1kom
4k7 2kom (ili 1kom + 1 vertikalni višeobrtni trimer od 10k,za podešavanje mirne struje ako se ide na ab-klasu!)
.............(or 1 peace + 1 vertical multiturn trimer 10k,for adjusting bias if is to be done in ab class!)
0,22r 5W 4kom
5r6 2W 1kom
kondenzatori:capacitors
22uF 2kom
100p 1kom
220n 1kom
1u blok (wima 63V) 1kom
47u 50V 1kom
22p 1kom
22n250V 1kom
470p 1kom
10p 2kom
100n250V 3kom
100n 2kom
100u63V 2kom
tranzistori:transistors
bc556 2kom
bf420 2kom
bd139 1kom
bf421 1kom
bc337 1kom
bc327 1kom
irfp240 2kom
irfp9240 2kom
diode:diodes
1n4148 10kom
1n4007 2kom
žuta led obična mutna 5mm 1kom (ordinary yellow led)
zy2,7 2kom
zy15 2kom
zf12 2kom
ic:
tl071
  • MOŽE I U AB_KLASI pro?itati tekst.txt
