WTH did you use for the front panel? 😱 You should remove side panels covering heatsinks, efficiency will increase a lot. Unless heatsinks are already oversized and you want to hide them somehow, so then thanks ok. Anyway, you are not hiding them very well 🙄Pinnocchios SYMEF . Enjoy![]()
All in all, look is pretty original, I like it.
For sure, I do the same until the final assembly... 😉I think it's masking tape protecting all edges/surfaces.
For sure
You should witness yacht assembly, until throwing a bottle at it.
Both stainless-steel and aluminum can be ordered cut to size and drilled, with protective foil on both sides, stays there until the finishing touch.
Zen Headamp
Mosfet Zen Headamp using IRF610
Metal base plate is preferred. Support the double sided adhesive with something long lasting. Air inlet or exhaust holes are needed.
Nice build.
Gajanan Phadte
Nice build.
Gajanan Phadte
I had just finished amplifier complete copy of TL 400,
Invite me see it
Invite me see it
Such a mess :-D What was the purpose of all that creamy stuff around the transformers? to glue them? Why not use a bolt and nut?
How could it be?yeap ...NVA style : metal screws and housings effect sound for the worst ....
It is a special top secret audio construction technique discovered byHow could it be?
- Post your Solid State pics here
