Power?
2x80W/8R made by 'wendipassundan'
WTH did you use for the front panel? You should remove side panels covering heatsinks, efficiency will increase a lot. Unless heatsinks are already oversized and you want to hide them somehow, so then thanks ok. Anyway, you are not hiding them very wellPinnocchios SYMEF . Enjoy
All in all, look is pretty original, I like it.
For sure, I do the same until the final assembly...I think it's masking tape protecting all edges/surfaces.
For sure
You should witness yacht assembly, until throwing a bottle at it.
Both stainless-steel and aluminum can be ordered cut to size and drilled, with protective foil on both sides, stays there until the finishing touch.
Zen Headamp
Mosfet Zen Headamp using IRF610
I had just finished amplifier complete copy of TL 400,
Invite me see it
Invite me see it
How could it be?yeap ...NVA style : metal screws and housings effect sound for the worst ....
It is a special top secret audio construction technique discovered by ..pseudoscience!...How could it be?
- Post your Solid State pics here
