I prefer 2 x OPA2134 + 2 x dual OPA627
I suggest OP627 on first stage and OPA2134 on second stage to get the best sound.
Mark Levinson no. 380 use OP627 + OPA2604
Hi Andrea and Quanghao
Do you plan a multi-channel version when this great success GB is done (to be set after a digital XO) ?
Jean-Louis
Jean-Louis
You should totally ditch the 2134 and use OPA1612. I have done some extensive listening tests (me and many friends) and the OPA1611 (single) actually sounds better than the OPA627 and OPA1612 (dual but same as 1611 otherwise) is much better than the OPA2134.
Some people I know totally hate Opamps but are ok with the OPA1611/12. Also the OPA1641/42 are the J-Fet versions and they are excellent as well.
You should try them
Do
You should try them
Do
Jean-Louis
Amanero company is testing a custom ASIO driver to use more USB DAC module as a single multi channel audio device.
This mean 2 usb cable for any stereo channels.
I will give you an update soon about this solution.
Hi, Quanghao!
As far as I understand quiet a few members are interested in a board for tube I/V.
I have 3 questions concerning this:
1. When are you going to make the board?
2. Could you incorporate CCS on the board itself?
3. Could you make an option for Russian 6S3P valve (http://www.russiantubes.com/prop.php?t=12&p=291)?
Kina regards, Daniel!
Hi, Quanghao and Andrea!
It seems my massage got lost among payment notifications.
Could you answer please?
Maybe it will make sense to wait a bit and ship dac base and valve PCB together.
Kind regards, Daniel.
Nice, so we can in realtime adjust the settings to our preferences 🙂I have integrated in the firmware the rolloff setting, fast to slow.
Hello Walter,
Copy the list in post #300, add your name and pay 1/2 in advance, see post #204.
thanks danny_66, and all friend!
quanghao
How much Current can the Shunts For the I/V deliver ? Enough for Discret opamps like Burson ?
total 60mA in this shunt
thanks
At this time we don't think to create a pcb for the vacuum tube output stage.
You can ask to Quanghao for a pcb of the power supply
http://www.audiodesignguide.com/DACend2/Cricuit-Suply-for-IV.jpg
used in the old DAC End 2
The vacuum output stage is very simple so you can assemble on air with the CCS by kandaudio.
For the power supply it is easy create a passive solution like my Phono End
Hi-end phono preamplifier
Burson opamp get too many current for this shunt
ok 🙂 So it is not for discret opamps . 🙂
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
