VSSA Lateral MosFet Amplifier
During this week we will make a comparative test...buzzing vs switching power supplies 😀
Yes, SMPS is dead quiet. VSSA on +/- 45 V definately at its max. BC550C/560C are on the Vce edge but no problem, did hard clipp tests yesterday, I mean DC at input to clipp it totally on one side and vice versa, no sign of any troubles. 😎
Sine clipp was at 86 Vpp, clear as nife cut like. :up:
To be better performer than any other amp, in home environment of course. 😀
Well, now it is time for those people that have build your amp to compare it agains some of good desing amps. This sounds very exciting😉
Did you try it with a non-regulated power supply?
can it drive 2 ohms speakers with no problems?
What is the signal to noise?
What is the input impedance?
sorry for many questions , but this amp looks like it is a very good amp and so far I like what I see from it😀
Hi lanchile
QA:
Yes. Look few posts back.
Yes, as long as output RMS current doesn't exceed 8 A. Output is short circuit stable (when no signal is present). Output impedance is less than 10 mOhms at 20 kHz, measured at PCB's output pin.
S/N: better than -100 dB
10 kOhm
It's even better than it looks. 🙂
VSSA test measurements with square waves. Input low-pass filter set to 970 kHz (-3 dB), output RC filter installed.
1. Plot - 50 kHz, 8 Ohm load
2. Plot - 100 kHz, 8 Ohm load
3. Plot - 200 kHz, 8 Ohm load
4. plot - 50 kHz, 1 Ohm load
