Class D Amp with LM566, LM393 and 2XIRF530
They are ceramic caps so i can safely use thes round orange ones i have a lot of,i heard they are also used for decoupling so it will work
BTW wima caps are expensive,and probably imposible to find in shops,so im using my ceramics afte you give me the ok
Or you can place an order with itead studio and get ten boards for 28 us dollars shipped, though this requires having access to the PCB gerber files, which i'd guess is a well regarded secret locked away at apex's PC. Assuming Apex dident just draw his pcb's with a picture editing program such as photoshop, ms paint or similar.
and no norazmi, you cannot use a LS series ic, the circuit assumes and requires a HC series ic which is a mosfet based ic wheres the LS series is bipolar transistor based, the LS series is also much slower.
thanks Tekko....
Anyone tested the over current protect? Will the over current in mosfet be reflected in output current sense fast enough? There's no delay after the trigger too.
Hi Azmi,
I've traced the circuit for the protection. It uses 2 of the NAND gates(pins 1 to 6) for shutdown control, the input for the pins 1 and 2 of 74HC00 (encircled in the attached pic) is normally "low", when there's a voltage across the current sensing resistor, pins 1 and 2 will go "high", resulting pin 6 to output high then triggers the SD pin of IR2110.
But there's no delay for the trigger, the 47uf connected in pin 5 is only for startup delay.
I'm afraid the protection will loop fast (assuming current sensing in speaker out works) and might lead to mosfet destruction.
