Hi Quanghao,
May I join the GB?
I need ONE SET of DAC base + I/V opamp + DAC chassis + Amanero
Thanks!
Kenneth
May I join the GB?
Thanks!
Kenneth
Sent my payment 305$ for DAC base + opamp I/V board + amanero USB.
Quanghao, pls confirm you have receive it. Thank you.
Is it too late to join this gb?
I've got a couple of quick questions. I've got an amanero, and got the acko isolator / reclocker on order (from acko labs) for the amanero...
I don't see why this wouldn't work together? It maybe a bit of an issue trying to fit it in the case (it probably need another standoff).
I've got a JG filter buffer coming too, I guess that would be a suitable output stage for this dac?
thank all of you interested in this DAC!
But I would like to continue working for you after the second time, hope you understand and wait quanghao.
Thank You and please wait!
quanghao
quanghao
I forgot to update my order.Thanks.
1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp+transformers+Chassis+amanero)
5. 1 x danny_66 ( DAC base + I/V opamp + transfomer)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k92 ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + tranfomer +DAC chassis)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base)
14.1x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + I/V opamp + DAC chassis + trasformer + Amanero )
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base + I/V opamp + DAC chassis + trasformer)
22. gjorgji (DAC base + I/V opamp + transformer + chassis + Amanero)
23. myfavoritething (DAC base+ I/V op +chassis + transformer)
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
25. bertchai (DAC base + I/V op + chassis)
26. kimgiin (DAC Base)
27. misterrogers (DAC Base)
28. malarkey (DAC Base)
29. TarnishedEars (DAC base + I/V opamp + DAC chassis + Transformers)
30. Boxi80 (DAC base + I/V opamp + OP + transformer)
31. 1x Ridsaudio DAC Base
32. meintan (DAC base + I/Vkit + transformer + chassis)
33. Luizl (DAC base + I/V opamp).
34. inforsit (DAC base + I/V opamp + DAC chassis + trasformer)
35. xtomm (DAC base + I/V opamp + transformer)
36,37,38 3 x kgkim (DAC base)
39. necplusultra (2x tranformers)
40. 1 x halook (DAC base + I/V opamp + Amanero)
41 juju35135 (DAC base + IV opamp + chassis)
I would really like to implement 12V triggers, remote in/out and perhaps a standby function to use as my digital only preamp. Any thoughts?
1. 1 x audiodesign ( DAC base )
14. 1 x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
42. la1209 (DAC base + I/V opamp + Chassis + Amanero)
no only 6v, but you need one more transformer!
thanks
Hi Quanghao,
I just sent you USD355 by PayPal, the 1st half payment of the DAC END-R group buy
USD(450+60+100+100)/2=USD355
Please check it, thanks!
Kenneth Lau
Kenneth Lau
thanks to Quanghao to re-open the list
42 rliyung/raoul (dac base + chassis)
Domi_78
Hi Quanghao
Just added my name.
43. Domi_78 (DAC base + Chassis)
Hi Quanghao
Just added my name.
according post #273
42 rliyung/raoul (dac base+chassis)
43. la1209 (DAC base + I/V opamp + Chassis + Amanero)
44. Domi_78 (DAC base + Chassis)
Hi Quanghao,
I have just sent you USD275 by PayPal, the 1st half payment of the DAC END-R group buy
USD(450+100)/2=USD275
Dominique Prod'homme
thanks
Quanhao,
No problems - happy to get another transformer. However, does the controller support standby and an external relay? I think one of your other controllers did? How about an option (perhaps a daughter board) to implement standby, a trigger output and remote in/out? Would be absolutely fantastic. I presume the chassis would be the really nice silver one that you posted previously rather than the black one in your most recent post?
Hi Raoul,
Remind you that mine should be #42, please refer to the post#269, please make a amendment for it, thanks!
Kenneth
Kenneth
Hi Quanghao,
Updated "44. Domi_78" -> 44. Domi_78 (DAC base + I/V opamp + Chassis)
Hi la1209 and rliyung,
Due to a copy/paste mistake from rliyung
Corrected "43. la1209 ..." -> "42. la1209 ..."
Corrected "42. rliyung ..." -> "43. rliyung ..."
41. juju35135 (DAC base + IV opamp + chassis)
43. rliyung/raoul (dac base+chassis)
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
