Modelling an L C R power supply
You can see what I get here. The choke input filter needs ~535V pk (~380vrms), the cap input filter needs 340V pk (~240vrms). Transformer voltages are rms.
These values are realistic. These are typical tube PSU configurations. When you look at a few circuits you will see values like these, some are higher specified for preamps, some lower for power amps and depending on type of amp and PSRR. If you are building a prototype build it point-to-point with plenty of room in the chassis so that you can modify it a bit if you end up with too much hum. You can increase the caps or add another RC stage, it will cost you a few B+ volts, but this is unlikely to be critical.
Okay, thank you.
With 10H (2x5H, which is the actual choke) and combined capacitance of 82u, I get ripple of about 2V. Is it possible? Is it a realistic result?
