Post your Solid State pics here
more pics!!!
more pics soon.....
M400
Hi, let me present you my HDAMP M400, wonderful sounding amp (as member lanchile said). lateral mosfets 2sk1058, 2sj62, ps 56vcc, 130w pc. Cheers !!!
Hi, I am glad to see your M400 build!!! These amps are very well design. and they sound awesome!. in my amp I replaced C1 for a Sonicap 4.7uf and I put them at the input terminals (too big to put it on board). I am using a TKD potentiometer connected directly from RCA input to amp as a passive integrated amp...it sounds wonderful;)
PS: These M400 sound so good that it replaced my Bryston B60 that I loved so much!!!...yeah that good!
This is a my diy amplifier based on LME49810 power amplifier driver.
Output stage-3 paire matched NJW3281 & NJW1302 ON semi.
The power source is a full-bridge power converter based on ETD49 core.
+/-60Vcc 800W.
Not ready yet but I did some tests and the sound is great.
Red heatsinks - nice! ;)
Any other pics of the power supply without the fan? :rolleyes:
Cheers!
Thank you Lanchile.I am using a Goldmund 27 clone as a preamp (active), I am in heaven here. Dear i have 2 Auricaps 4,7uf , soon i will put then in C1 posistion, they are big also. Mhouston i always use dual mono in my amps. In this case i use 40.000uf per channel. I think it´s enought for a AB CLASS amp.
Nice build you did Mircea, congratulations,
cheers
Rod Elliot preamp version with few changes and volume control selection sources Chinese.
I used LME 49720 & LME49740 from TI (National Semi).
Enclosure saved from a broken switch and front panel dummy rack 1U.
The sound is very clean.
