The Advantages of Floor Coupled Up-Firing Speakers
Any wave interference/addition/superpo
HTML:
sition applet on the net is a reference. Here is one of the nicer examples
well, very nice but I thought Your argument was from psychophysics and psychoacoustics, You know, when You say "Gestalt" etc. Was "Gestalt" taken into account in this nice applet? :) and what about the precedence effect in the vertical plane?
oh c'mon Scott! :D I know what's diffraction
what I don't know is what You mean by "the point of diffraction" :)
:p
-that if it weren't for the length of the wavelength vs the size of the object it would be a reflection.
Nobody seems to reference reflection in the context of wavelength, but it's a necessary distinction from diffraction. ;)
Ex. a 250 Hz wave diffracts around your body while a 1000 Hz wave reflects off of your body. Ergo: If a 250 Hz wave diffracts around your body it's not reflecting.
:p
c'mon again! :p:p I know that and You know that I know that :D
I ask where is the formula that tells us that 500 Hz wave doesn't specularly reflect under the conditions of Elias' experiment? :)
I tried ceiling deflectors in FDTD simulation.
The speaker is 40cm box with 30cm radiator. Freq 500Hz. Floor is removed and vertical walls are absorptive. x and y axes are in meters.
This type deflector does not remove ceiling reflection at the listening position, but it breaks the wavefront spreading the energy in time domain. A diffusor ;)
- Elias
ok then - in other words: How can You tell that a 500 Hz wave doesn't specularly reflect under the conditions of Elias' experiment? Give some reasons please :)
500 Hz is 2.26 feet (using a wavelength calculator).
Acoustic center for the driver on-baffle virtually connected to the floor is within 2.26 feet. Within 2.26 feet the wavelength is bounded to the baffle and floor (in the same manner a large wavelength will bound to and diffract around a smaller object). If it's enough above this amount (as in the meter example) then sure enough - reflection for this wavelength. Put enough of a delay on that reflection (again, relative to the wave's length) and you'll get an echo.
Thanks! What happens when you place them like this:
attachment.php
Also try longer panels and/or closer together.
It strange indeed. The measurements should reveal similar (15dB) difference as you measured on ceiling absorption.
Or are your speakers somehow nonconventional ? :)
Not at all, just a pair of Orions. I may be blind? :eek:
2m distance, mid heigh 87cm, tweeter height 107cm, mic at 1m, ceiling 2,25m.
pads on the floor only:
pads on floor and on top of the speaker:
Obviously one is missing, no floor, no ceiling pads. silly me. :mad:
I did think about a deflector on hinges first but it seemed too difficult on paper.
Are You sure?
Isn't it that for a reflection of a wave to occur the reflecting surface must be no closer than a quarter of a wavelength from a sound source?
The 500 Hz wave will be reflected. There is no doubt about it. If the floor is "mirror-like", the reflection will be specular. No doubt about that too.
Rudolf
then why would it be disregarded by a human auditory system?
once again a couple of links to information that a floor reflection is an important distance and elevation perception cue:
Francis Rumsey, Tim McCormick "Sound and Recording"
Linkwitz's 2009 AES Paper
Human Systems Integration Division @ NASA Ames - Projects
http://www2.ph.ed.ac.uk/teaching/course-notes/documents/67/1569-SoundLocalisation1.pdf
moreover:
the floor reflection is a very strong distance cue at close range under semi-anechoic conditions (i.e. if you want to gauge the distance of that sabre-toothed tiger or the potential mating candidate).
when a listening room first reflection is strong and early, it will dominate your sense of distance.
Re: [Sursound] Distance perception
Did anyone say that it is disregarded?
In Elias' example it is almost a grazing reflection. That means, that the time difference between the initial sound and the reflection is quite short. And the angle between initial sound and reflection is narrow. Compare that to the wavelength of 500 Hz and tell us, what aspect of the reflection makes you still worry.
Rudolf
For normal living room environment, the situation I'm most interested, I think the ceiling deflectors are very unpractical and not appealing. There should be found another alternative method to achieve low floor (and/or/or not ceiling) reflection at the listening position.
in that particular reflection nothing really worries me
I am trying to understand the results of Elias' test:
1.5kHz low pass: Less treble can be heard from the woofer than with 24dB filter. It's hard to say the height of the image. It seems to be rather sensitive to head side tilting. Tilting head 30 degrees to either side and image is on the floor.
1kHz low pass: The image seems to be at the ear height although it is not very sharp. Tilting of head sideways shifts image close to floor.
700Hz low pass: The image is clearly at the ear height and 1 or 2 meters behind the speaker. Tilting head side ways causes image shifting downwards.
400Hz low pass: Same as 700Hz, image at ear height and head sideways tilting pulls down the height a bit.
it is clear that with 400Hz low pass and also 700 Hz low pass the shifting effect is not that severe - perhaps because the reflection is barely audible? and in turn perhaps this is because the angle is relatively narrow, the delay is relatively short and the wave is relatively long?
just a hypothesis
Could you run a simulation with the deflectors oriented like shown in my last post?
