Pictures of your diy Pass amplifier
Official Court Jester
Joined 2003
in that case - be sure that either screw is electrically isolated on one ( even better - both ) ends ..... or that your screen-bell is electrically isolated from bottom of case , so you are not having shorting turn through donut itself
wire in windings is also isolated from core , electrically ..... but not magnetically :devily:
Toroid shield
Hmm... I didn't know that there still are possibilities for the electrical loop when trafo center is "metal free", but now that you say it makes sense with the magnetism and all. Well I have to make myself a nylon bolt then. :)
Another option, to preserve the clean looks of the shield. Use a good silicone to bond the shield over/around the transformer. Silver solder a piece of wire or braid to the bottom edge of the shield, and run it to a good chassis ground (or just let the shield "float", ungrounded, if hum is not a problem). Result is a grounded shield, with no bolts/nuts showing in the top, and with no dreaded "magnetic loop" around the toroid core. Voila.
(Now, back to the "photos" in this Pass amp photo thread!.....:D)
Great work on the cover! Would the value of such a cover be to reduce stray fields or the transformer's mechanical noise?
The transformer that I bought is designed for audio applications and have a minimal magnetic leakage so the cover is probably not necessary. I made it because the inside of the amp will be more "clean" looking in my opinion. If it also shields the trafo a little I consider that a bonus. :)
I'm with you 100%. It does look great and worth the effort on that basis alone. I was just curious because it looks tough to have so many diverse elements in a case without interference. I wondered if some level of scrutiny for their physical arrangement wasn't worthwhile. Then... I was thinking way back to my EE transmission line lab and our measured results for line-of-sight, ungrounded shields were not very good. Someone here may have some real emag experience to refute my observation but maybe an insulated cover would be mainly cosmetic? but hey, from a guy that buys chrome valve covers... i still like it :)
F5T V2
Finally everything is finalized.
It has a bridge rectifier for the two channels as the original.
Built a soft start and a low noise fan at the top.
All tuned, and now it's just music.
