500W PA amplifier with Limiter
its mine, b500 tef with 3 pair
Again, thank you mile
Just finish build another 3 B500 amp. So amazing, i don't have any difficulties to finish this amp. Again thank you so much for sharing your knowledge.
Warm regards from bekasi indonesia
Gassanov fuad.
2 x B500 (BTL) for sub wover
Hi sir mile....can i use 2 B 500 (bridge mode) to drive 8 ohm 18inch subwoover?
How much safety vcc for this amp, 55vac (76.5 VDC) is enough for BTL mode?
I need 1000 watt 4ohm amp to drive this sub. Thx in advance
Warm regars
Gassanov fuad
Bekasi indonesia
Warm regars
Gassanov fuad
Bekasi indonesia
B500 in bridge mode can work only with 8 ohm load, for 4 ohm you must use 8 pairs of outputs instead 4 pairs per channel.
Wow thx for super fast respons. What i mean is, i use 2 b500 in bridgemode to drive single 18inch 8ohm subwoofer (not 4 ohm subwoofer).
So my calculation is. B500 work in 500watt 4ohm in btl mode so dual b500 will give me 1000 for 8 ohm. Correct me if i,m wrong.
Thx
