thank you, PetruVYes but 2x 55v 7-10a transformer is ok for one chanel
regard
Noooooo i was asking a question not answering, it may be wrong what i saidthank you, PetruV
regard
but, I'll try use 15 A, 2x 55VAC, may be better than everNoooooo i was asking a question not answering, it may be wrong what i said
that will be 1500w wich will be good even for two chanelsbut, I'll try use 15 A, 2x 55VAC, may be better than ever
Hi ahmadfay can you share layot & skemaits mine, b500 tef with 3 pair
regard
Your design is interesting,the way you have the transistors mounted
This test only, next i will be using 7 pairs final transistor.
regards
Again, thank you mile
Just finish build another 3 B500 amp. So amazing, i don't have any difficulties to finish this amp. Again thank you so much for sharing your knowledge.
Warm regards from bekasi indonesia
Gassanov fuad.
Gassanov fuad.
2 x B500 (BTL) for sub wover
Hi sir mile....can i use 2 B 500 (bridge mode) to drive 8 ohm 18inch subwoover?
How much safety vcc for this amp, 55vac (76.5 VDC) is enough for BTL mode?
I need 1000 watt 4ohm amp to drive this sub. Thx in advance
Warm regars
Gassanov fuad
Bekasi indonesia
Warm regars
Gassanov fuad
Bekasi indonesia
Warm regars
Gassanov fuad
Bekasi indonesia
B500 in bridge mode can work only with 8 ohm load, for 4 ohm you must use 8 pairs of outputs instead 4 pairs per channel.
Wow thx for super fast respons. What i mean is, i use 2 b500 in bridgemode to drive single 18inch 8ohm subwoofer (not 4 ohm subwoofer).
So my calculation is. B500 work in 500watt 4ohm in btl mode so dual b500 will give me 1000 for 8 ohm. Correct me if i,m wrong.
Thx
Thx
Yes but in reality you will get about 900W at 8 ohm.
Ok thx alot sir.... Thats enough for me.
Again thankyou soooooo much
Regard
i used this oneHi ahmadfay can you share layot & skema
regard
salam kenal...
i used this one
salam kenal...
hai ahmadfay can you share pdf file of pcb design
salam kenal
My new APEX B500 in Horizontal position (tested and working) with APEX protect using NE555 IC in progress.
Many thanks to APEX....
hy,can you tell me skematic of protector with NE555
regards
- 500W PA amplifier with Limiter
