after few tricks ( I wrote about ) , one can coax mains wires ; old VGA cable good for skinning and some heatshrink .....
so - leave xformer where is
though , Generg's remarks about small xformers are valid - some quick mock-up for shielding will tell what's needed
I had trouble with the unit unbuffered, the source was 150R driving them too, the speakers seem to motorboat. (not hum).
Putting in the 1k/47k helped a lot, but it performed best sonically with the Toshiba JFETs in place. It was hard to go agianst the masters recipe.
My problem is solved!
It was a simple, stupid failure. I connected my pre's signal to F6's ground.
Stupid me!
Now everything seems to be fine. There is a lot of bass and enough gain for my speakers!
Thanks for your help! I'm going to listen to music now! 🙂
Stupid me!
Stupid me!
Very nice! 😀😀
That is the way I did often my distortion measurement..... 😱😀
Sorry, of course the M2 xformer is much more susceptible for hum, because it amplifies the voltage 5x.....!
The Jensen does not do this, so the position might not so important to care for....!
ZM has been nagging me for information on the F6. I have a very nice
sounding prototype, but the design and the article that accompanies it
have some details remaining.
However, I can afford to put out this teaser:
This is my F6, There is something wrong with it?
thank you for you help.🙂
what means having connections in high instances ......
this time , some wakoo friend in Vaterland ....... my goldene Ohr Freund Generg sent me geschenk
ZM not worthy , for oumptheenth time
Hope you have fun.....! 😀😀
Tea-bag and crt have designer qualities, ....even woman would buy these boards!
An official board. Where do the SiTs go.
SICs maybe , nope SITs ; they'll go here :
Thats not any SiT i have seen
Will tl431 bias schema from ealier work for SiT2 mockery. No way i understand all that Babel😀
don´t worry 😡 I cloned the board already......😀😀
there was ZM written in the corner........😎😎😀
SICs maybe , nope SITs ; they'll go here :![]()
Will R085 buggers work here?
When will the Turbo be released?
- F6 Amplifier
