Canned Crossover Design - What Next?
I might be able to get a buddy to help measure the impedance (tomorrow)
So far some songs are sounding very nice. However the woofer is not rolling off at 2200hz, still going to 3500hz or so. (I didn't think the woofer would roll off easily)
The tweeter roll off is close, however to loud.
L-Pad (now) R1= 1.0 ohm R2= 50ohm
What are the sensitivities of the two speakers
Noob alert!!!! I understand the Q. but no A.
I'm more of a no-controls crop dusting pilot when comes speaker building (saw your Bio)
He he he, ok so this is going to be difficult then.😕 What one has to do is test the speakers and measure their impedance at the chosen crossover frequency. This figure is then used to calculate the crossover values as well as the L-pad network. sorry there is just no other way.
But I can attest, he has very good ears and is game. We just have a lot to teach him.
The Silver Flute has breakup issues he has not addressed. This will cause pronounced upper mids. The crossover is a tad too low which is very bad for the XT-25 as it does not know how to stop below 3K, This also causes pronounced midrange. I think they are a tad light in the bass and that would be throwing off the balance. The crossover he is trying does not have sufficient BSC and is actually reducing the slope of the tweeter crossover with that 46 Ohm resistor. More pronounced midrange.
The boxes are a bit of an interesting challenge. Step is going to be purely by measurement, but the typical pole of 200 or 250 is probably a good starting place. I am going to see how those tweets do in such a small round baffle.
As a side note, I never really looked at the SF drivers as they are low end, but they may be a real champ for the price. Take a look if you need a budget woofer.
Thanks TVR, and btw, the laptop with the speaker programs/mic setup was impressive! Splice...Way Cool!
The bass is good, we just didn't hit any songs with some good bass, e,g, the other day they sounded like sub-woofers; also new boxes - better/thicker wood. I might build more; extra pair here btw......
Now then - Odougbo has been known to pull a rabbit out of his hat now and then.
I'll have to remember to bring some of the music I know next time. You see, I don't listen to either country or western.
Build the crossover they recommended. From the plot, it looks quite reasonable. I only worry if it keeps the tweeter in the happy range. Close.
Study it a bit. You will see they shifted the woofers crossover down, but the resistor is providing a bit of a shelf effect and they are relying on the woofers rolloff due to inductance. So pseudo second order and BSC with only three parts. We may need to tune the notch to your specific drivers, but If I remember, it is very close.
Pic of mock up of LEAP xo - DIY style (or very confused man 😕 )
Only one done, but parts needed may be today/tomorrow.
A few thoughts - the bass is nice, pretty darn full sounding. The tweeter is getting a workout, maybe more than I like for a inexpensive tweeter. The crossover point does sound even/smooth with generator sweeps.
Note 11 degree angle boxes from the top view 😀
I'm really loving this box idea, it's way easier to make than it looks. I.e. cut a few groves on top and bottom panels - cut sides/back (12" - btw) and glue it up on corner of a table - it self alines. Used 4 - 6 penny nails to press back "in" while clamping down.
One thing I've been doing for back panels is gluing 2 - 1/2" sheets together for a 1" back - I highly recommend that ploy!!
Tried the xo in last post - okay, thought I lost some bass with the 16g series woofer coil. I switched it out with a 14g and used 14g feed wires, quite the improvement (bass).
I thought the tweeter sounded a little hot on some songs, so swapped the 1st tweeter resistor; 2.2ohm with a 3.3ohm ....They sounds nice, they pound, kick, slam and have nice high end.
(ordered some steel lam inductors - will try that next)
I thought this woofer was going to be a peaky monster when I took it out of the shipping box (large magnet) - and I guess it is, but with the cork/felt/large coil that's all gone.
The woofer circuit has the typical 3 parts to ground (besides large coil) coil-cap-resistor; I can't wrap my head around what that does 😕
Also curious why this woofer is only $29, it's built really well, even self seals - but need to cut exact hole size!! I.e. if the hole is 1/8" to large, won't seal with out extra tape/sealer.
So yeah, amazing life-like guitar and bass strings, not sure if I ever heard a speaker so accurate.
btw, don't you have a pair of X25 tweeters? hint hint.
Hi Odougbo, when you say coil cap resistor, do you mean in series and shunting to ground? If so then it is basically a "notch" filter. Effectively what it is is a bandpass circuit with a resistor to set how much cut you have. The coil sets the upper frequency range and the cap sets the lower frequency range. The resistor determines how much of the energy shunts to ground rather than going through the voice coil.
At least that is my understanding of what is happening, Someone jump in and correct me if I've got it all wrong 😉
Tony.
A Three parts in series, shunting the driver is a "series notch filter". It is a lot slicker than just setting two frequencies, as the cap and coil hey work in tandem as a resonant circuit at some center frequency. The resistor adjusts the depth of the notch. It works much the sale as a parallel trap, which has the three parts in parallel, but in series with the driver. This is to kill that horrible breakup the SF has.
Google Image Result for http://www.speaker-designer.com/mobile/images/series_notch_final.png
Redirect Notice
A bit of googling showed that my description is off, in that as tvrgeek says it is a resonant circuit. I've done the parallel type notch filters myself, but have not tried the series ones (except in some sims) I found that the series ones seemed to be better for broad peaks which is what gave me the impression that the worked more like a bandpass circuit than a resonant one.
Tony.
I have to laugh. We rely on Google and Wiki so much these days, we have been accused of not remembering anything. Freshman Engineering Orientation circa 1974: "Never memorize what you can look up. Understand the concepts and look up the details" I wonder Dean Blackwell would look at that now?
Use the parallel on tweeters and mids where the DCR of the choke is not an issue. The series notch is more often used on woofers as the DCR is not dropping the woofers efficiency. My experience, I will try a steeper crossover first, but I did use a notch on some Dayton RS's. Just don't put a bottomless (no resistor) series notch on a woofer as the amp will not like that at all. As a rule of thumb, I like to keep the smoke inside the wires.
There were quite a few posts on the X25 tweeter recently, and now has me second guessing if that was the best choice for this 2-way.
No complainants about the $29 SF woofer - Outstanding lower register/baritone and bass (with circuit shown).
The tweeter just seems to be "shining" but it's not that great. I have the X25 tweeter in Madisound HDS kits and the mid sounds are very smooth, however, they only down to 80 hz and these are rolling off into the low 40s
Any thoughts on tweaking?
Go find another tweeter :usd: ?
