QUASI Amplifier for Beginners
Mr. Lelut, P.c.b. from your design
Mr. Lelut,P.C.B. from your design, where is the component list and circuit
400W into what impedance?
The forward-biased voltage limit is only 60V, so you will need to build a bridge amplifier to get any real power.
Three pair per each half of the bridge on ±30VDC should do what you want. You will want an output triple to bet enough current gain, use another pair of 3055s as drivers, and TIP41C/42 or similar for pre-drivers.
250-500wats at 4 ohms,maybe 2 ohms but i only want to use only one speaker a big one
