100W Ultimate Fidelity Amplifier
my ax 20 with 5 pair
hi sir mile
i want use this OCP shematic for another amp
i use AX12 in my car with + -30VDC
http://upload.tehran98.com/img1/mwlg...7im5mcuknf.pdf
i want use this shematic for a class AB OCP section
my supply voltage will be + - 35 VDC in this amp
can i drive a relay with S output pin ?
my relay is like AUD600 power section relay
it must protect in 3A and when the out put is shorted
which one off resistors must be change ?
thanks
hi sir mile
thanks
You can find PSU with protect in this thread post #95. This PSU have DC, OC protect and clip leds.
http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-10.html
Apex B80 is ready to go...
Dear Mile,
Thanks for the nice, compact, portable design. What is the recommended supply voltage and current for B80 to drive a 2 ohms subwoofer?
