Mr. Mile,
This gonna be my next project to follow, please let me know if you found an error.
Thanks...
Does the pcb right?
sr200 & ax20 what one is better than other?
sorry for bad eng
Does the pcb right?
sorry for bad eng
This is AX-20 extended with 5 pair, but "NOT TESTED" yet.
I will update and confirm soon once pcb is tested.
Thanks for your effortsThis is AX-20 extended with 5 pair, but "NOT TESTED" yet.
In your opinion, which of sr200 & ax20 is better?
I haven't build SR 200 yet, i suggest you to ask Mr. Mile, he is the right one who can answer all your questions about this 2 amp.
Finally figured out the problem...one of the resistors was miss valued by quite a bit.
I fixed the resistor and took the amp for a spin. Running about 65 mV across 0.22 ohm emitter resistors and the large sinks barely get warm.
I am really going to enjoy this amp...good treble...commanding bass and the amp is very quiet. I still need to clean up a little wiring and post a pic.
The amp boards and psu board are all homemade etch via toner transfer method.
Thank you Apex!
Thank you Apex!
Here is a pic...The speaker protects are not hooked up yet but it did not thump at all upon startup or shutdown.
Nice?! It look´s great man! Well done!
Nice work, and nice picture. I suggest to revert positions of transformer and PSU and you have short wires instead long from AC input to the transformer and from transformer to PSU. Bias transistor (BD139) must be connect on heatsink with outputs.
Apex hai ...hi all,
why ax 20 which I have made the volume more slowly than the ax14, if this is so the character of ax 20 (ax 14 TEF)?
thanks
what is my post? is there any comment from you? thanks
mr apex.., good advising! i am going to use my stock mj15015s and '016s in Nazirdigi's 4 pairs ax20. as i read the MJ's pdf online i knew its less powerful than what they are using here as powers. i am planning to maximize as possible the supply voltage to its safe extent. what can you advise? thank u vry mch sir.
Hi miles, I assembled AX-20 amp I have attached layout. Problem with this layout is, there is no connection between Q9 - Q18 and Q8 - Q17. I easily fixed by using MJE340-50 lead as jumper at copper side. My problem is I am not able to adjust bias, amp is playing music every thing seems right.
I connected amp in series with 10Ω resistance, when nothing seems to burn I put fuse and tried to adjust bias but was not able to, even winding trim-pot to full. Amp was playing music but with crossover distortion at low volume.
- 100W Ultimate Fidelity Amplifier
