Canned Crossover Design - What Next?
Mike,
Will Box Port II switch over to rectangle ports? - WinISD didn't like all the manipulation, but this what I came up with.
I'd like to keep the box about a 1" less deep than the TB, i.e 9".
(the extra white line is exaggerated)
A few revelations:
Both woofers TB W5 - SF W7 are about the same size (OD), so the TB box is a good example (e.g. don't want to get close to edge at front)
Using same footprint as the TB box, cut about the 1" off the back, that will make the ID height 11" (for a 13 liter box).
(the TB W5 box is 14-1/2" ID)
Going to use scrap wood and build one test box, make sure there is minimal port noise.
[W5- W7 - W BOX - How'd that happen?]
If you really want to get your teeth into something, you could try akabak 😉 Tony.
Hi Tony
Thanks for the recommendation. I heard that akabak is very powerful. Trouble is I don't have the time for steep learning curve. Too much work already.🙁
Hi ODougbo
I simulated the W17RC with Bass Box. The 2" diameter port length is almost the same, which means both are accurate.
For a rectangle port:
Height = 0.5"
Width = 6"
Length = 6.9"
A 1 inch height is not practical. Length is more than 12".
So going as planed. Used square vent strips just in case this is a flop (port noise).
Tuned at 43hz now and sounds fine; will cut flares in ports (vent strips) - to move tuning up to 49hz.
Hi Mike, I've had enough of a play with akabak to know that I'd like to become proficient in using it, but like you I really haven't had the time to do so. There is actually a good dummy's guide here on diyAudio which is enough to get going with simple projects.
Perhaps when I start to think about new cabinets for my Vifa M26WR-09-08's I may get a bit more into it. I'd like to model a double chamber reflex.
Tony.
Yes, didn't take long to get to 49-50hz (rounded vent strips)
I though the way it went together was good/fast. I cut a dado around the top and bottom plates and then nailed the back/sides on - then clamped vertically while the glue dried.
The goal is to make the dado just deep enough for the side panel and vent strip (mdf) thickness.
Thought it best to make template for the vents (the 1st set were beltsanded).
This is pretty simple, just attached to work piece and flush with router.
Going to play one all day here - then check tuning (-; (-;
Perhaps when I start to think about new cabinets for my Vifa M26WR-09-08's I may get a bit more into it. I'd like to model a double chamber reflex. Tony.
Hi Tony
Double Chamber Reflex are not very popular but they have their attributes. The main advantage of a DCR is in the Mid-Bass. It is actually a combination of a BandPass and a Bass Reflex.
I manually calculate the DCR with the help of Claudio Negro website. When I did a FR sweep with LMS, it's quite accurate.
Mike,
Can order parts Monday, what gauge wire should I purchase for the inductors?
Also the large resistor with the (BSC I guess); picked up 50ohm the other day (not expensive) will that work?
I standardize all my inductors with 18 AWG air core types.
50 ohms is fine. I usually use 10W for testing. Once final, I switch to 20W.
If the 0.95mH is unavailable, you can use 1.0mH.
This network is a Bass Shelving Filter, not really a BSC. I like to hear mid-bass in my music. If the lower bass (like 40Hz) is a bit lacking, I can always add a Sub later.
