Hornresp
Hornresp Update 3020-121219
Hi Everyone,
There were some inconsistencies in the operation of the 'Compare Captured' menu command. This bug has now been fixed.
The Loudspeaker Wizard baseline for combined responses assumed unmasked resonances even when the masked option was selected. This bug has now been fixed.
Kind regards,
David
I'm guessing you do what I do. Check the program against a well known file. If the output is strange, then somethings afoot!.
Hi Mark,
Nothing so organised as that 🙂. I tend to just keep trying different things at random, and every now and then I notice something that is not working as it should. That is how I found the latest two bugs.
Kind regards,
David
Eee PC 1000HD laptop & Windows XP. I tried multiple times.
Hi BP1Fanatic,
A question for you - what is your Operating System, and your display screen resolution and text size settings?
I would like to understand why your Hornresp input parameters window is as shown in the first attached screenprint - in particular why the input boxes and text are so large, and why the word "Previous" in the leftmost command button is wrapped over two lines.
The second attachment shows the input parameters window as it normally appears, using Windows 7, a screen resolution of 1600 x 900 pixels and a text size setting of 125%.
Thanks.
Kind regards,
David
