F6 Amplifier
With F6 and F5T trimed to similar distortion ratio at 1K, sou d is definitely unique to each design. I hate that SS fets dried up. This amp was going to be a great teaching tool for vlamp builders. F5 is trimmable, but doesnt seem to offer the range.
Suppose H2 and H3 are independent variables. There maybe a handle or a tweak [e.g. a Zen Pot] to increase and decrease %H2, and a second but different handle [?] which does not affect %H2; and also increases and decreases %H3 at will. Now I have the making of a two level factorial design leading to 5 experiments: A % THD analyzer is needed.
  • H2 High and H3 High
  • H2 High and H3 Low
  • H2 Low and H3 High
  • H2 Low and H3 Low
  • H2 Center [(H+L)/2] and H3 Center.
The above experiments are expected to yield 5 different sonic signatures because each distortion setting is a unique combination.
So, does the design of F6 have two different "tweaking handles" to independently vary H2 and H3?
Thanks buzzforb. The article on F6 by Mr. Pass has a wealth of info in a few paragraphs. I'll sort it out.
Mr Pass's article in 6moons has a great explanation on the specific handle [degeneration and JFET matching] to manage H2 and its different manifestations. In lhquam's post #s 3184 and 3186 he separated H2, and H3 from Total %THD. For example, in post 3186 he compared simiulation with actual results on TEASER-6. At 500 Hz, He found H2 was ~0.008%, and H3 was ~0.005%.
Truly low H2 and H3 numbers for TEASER-6. Suppose one operated diyF6 in Class AB mode. Will its comparative H2 and H3 be much higher? Will more H2 and/or H3 translate to better sonics.
I completed F6 with IRF240's.
I used 1R Source resistors. The bias only went to ~500mv with existing 5K Pot.
Assuming I go, to .5R resistor, I think this will give me enough room to bias higher. I was too scared to add pots across the source resistor. With IRF240's I am not sure if that's a good idea, assuming the overall source resistance goes below <.5R overall.
If not I was considering changing R3-4.
Any thoughts?
nothing is stopping you from testing it
:devily:
Zen Mod. Here is what astounds me by using this example:
  • 0.1% H2 is 1 sine cycle of H2 in 1000 sine cycles of the fundamental H1.
  • The amplitude of one H1 in a reference 2.828 Vrms into 8 Ohms [or 1 W] is equal to (2.828 /1000) = 0.00283 Vrms.
  • If the amplitude of one H2 cycle is equal to that of one H1 cycle, then the answer is 0.00283Vrms across the same 8 Ohms simultaneously stimulated by H1.
  • What is the output power attendant to H2?
  • P{W} = [V X V]/8 = 1 microWatt.
  • But fortunately; human hearing is 1000 times more sensitive in detecting H2 than H1 [just playing with working numbers].
  • Thus, the actual output power from H2 is 1 milliWatt.
In my previous post [Class A/B diyF6], I wanted to raise the power level of H2 to 10-100 milliWattsi in 1W total output power. Afterall, H2 is a desirable distortion; within limits.
Good looking boards. Yup - you need to put LEDs in series or use zener diodes up around 6 volts.
Any thoughts?
