F6 Amplifier
After the discussion of twisting , rotating and shouting about transformers given that I am using a choke input I decided to measure the AC at the outputs of PTP F6. I get 4.5mV and 4.7mV - obviously higher that lhquam and Nelson - is this out of acceptance range?
just did hand simulation - moved inductors away from onetics but on top of mains - the AC at output dropped from 4mV to 1 mV
May have to rethink PSU - used this because I had xformers with 2x 30V secondaries and a set of inductors and wanted to get up and running 😉
I was wondering what your rail voltage is after the 8 mH choke input filter with 30 VAC windings on the transformer?
Do you have two chokes, one for each rail or can you put the choke on the common ground and use only one rated for twice the amps?
Rush
Yes, that is essentially correct.
The simplest way to think about the role of the pot is as follows:
  • Let X be the ratio of the wiper-to-source resistance to the end-to-end pot resistance.
  • The effective AC degeneration resistance is X times the source resistance.
Ladies and Gents. Is there a certain constant ratio of H1 to H2 to H3 [say at 1KHz] which is a human trait; meaning this ratio which suits lhquam is equally transferrable to buzzforb or any DIYer worldwide regardless of race, age, sex, etc.? Is this ratio expected to be a constant in production F6; strictly from a quality control practice? Besides the F6 amps of Mr. Pass will be bought by diverse people who will use them with unknown loudspeakers and in unknown accoustic environments. Your thoughts please.
Best regards.
