ESL Diaphragm coating
All i can say... some one better look at this Turtle wax..F21..Super Protectant..
Best top end i have ever got out of any coating. for esls
..i have had it in miny setup for over 25 weeks...latest CLS...over the top...
an it get better with time...nuts i no....... i need other to give input ...
$3. US well do 100 panels...thanks
I may try it on my newest build.
After I get it running I will build a second set of frames for it and compare it
I am glad to hear that it is still working after this long!!
I had thought that some one had stated that it had started to diminish after a bit of time.
Cheers !!
jer 🙂
thanks...geraldfryjr...were talkin litte coate... i go over the mylar two time...thats why the topend is good i gess
i use whit noise..to see how the high frc are on any given ESL panels...it all most like it pinatarts the mylar...but that cantbe ...can it?
As far as I know nothing really penetrates mylar or bonds to it very well.
How transparent is it, Is it more clearer than the Licron Crystal that I use?
jer 🙂
Yes on the Martinlogan you can tell it on the panels...thay look new..Here what i have found...
is any coating that looks like what you have posted work fine but push the mid out..thats ok...it works..an you can get vary high SPL..An some well like the sound.. Even me....but after time i hear that the top is rolled down..
this is how i hear...not sure we all hear the same..but the bass tranzits start at the Vary top on these ESL panels.... thay must have as mucht topend as i can get..here in fl..the air gets wet eze...thay sound dull..that why if you cant open the panels up an clen it or re-coate for get ESLs...
now with the Acoustats panels have a larger gap from the mylar an the panel.. for get the wool type pads on the back...
but with mods to the 121 interfaces.. there good to go with AC on. .as we all now the dryer the air is the better Any ESL works...thanks for the pix
I used tishu..it not hard to work with...i clen the mylar with water...spray the tishu with the t. f21... spray it in a 1-2" line.. One time...an just pull from one sider to the other... not from top to bottem... i go over it twice ...lite coates.. so lite you dont see....Put it togather an play....If you put it on hever i think you get more mids...
I had said befor.... i think it fill the vary small poars in the mylar...look if glass has small pores... mylars dose..
Look ...i think most coatings do this....
But this work good for me.....
Last night i had FM on...thay were playing LPs...gofi...i could here all the surfus noise... like i was plaing Lp,s...Nuts i no....$3. you can do 100 big panels ... i am going to get a nother bottel ...the my chang somte thing in this stuff......
Like Moray James said to me long ago there a lot of wax type coatings out there that well work... it has not been tryed...good luck i hope it works for you..
This not right...Should have said
.Yes on the Martinlogan you[ cant] tell it on the panels...thay look new..Here what i have found...
can you put this coating on so you can see it .....yes..but thats not need...
An as for how long ML coating last... i can say...i have open up about 10pr ML panels that had low ouytput... most had no chang in output after clening.... water only..An after new bias feeds...one up left an right side of the panels.....not just the ML way...just up the right side...hell thay could put one on the right an left...so new out of the box you would hear them the same...... with only one feed on the right.... one panel was lower than the other... To your ear...new
But then with this coating... Or could be any good coating...thay sound better than any were new....All these ML panels were over 10years old....
It is more the new Bias feeds... that turn the panels on....Any good coating well work... if ML had put the bias feeds all the way around the panels like thay almost did with the biger panels like this pix of the CLS...it just a U bias feed....Thay would have got the output that these GReat panel can putout...but then thay would have not sold New panels...good luck...
Never read the whole thread, but I was thinking of building a electrostat. Wouldn't roughing a stretched mylar film with a 1000grit 6" body sander make suitable surface for coats to stick to? Al
Roughing the surface is not necessary.
You don't want a rough surface on the diaphragm as this would promote the leaking of the the charge to the air from the microscopic sharp points and edges.
Roger Sanders and I had talked extensively about this and that is how he explained it to me.
Also mylar is a very tough and inert material and the cutting action of the abrasive would weaken it as it is very thin and slightly brittle per say.
It would most likely cause it to break easily when tension is applied to it.
It would be great to see another DIYer do an ESL build as it is really worth the undertaking and the end result is extremely satisfying!!!
There are plenty of us here to help you should you have any doubts or questions as to how to get started.
There are several different ways and methods to build them.
They can be made out of almost any thing and any size you wish.
I like to build little desktop models and I will be building a bigger set sometime soon.
Here is a link to my Latest builds,
ESL Builds and Works in Progress
Good Luck !!!
jer 🙂
I agree with Jer... roughing the diaphragm is not necessary; especially if using Licron Crystal coating-- it's isn't cheap ($50 a can with shipping) but it's light and durable, works great and it's formulated to stick to plastics. The center spacers on my latest ESL panels are bonded directly to the coating and haven't come unstuck in the 3 years since. Some other coatings may work well too but I have complete confidence in Licron Crystal.
CharlieM..
You are right about your point.. an i have trust in what you say...Your work is some of the best ESL diying i have ever seen....An thank you for giveing us all the info you have.
I just wonted to try to find what would work... an in my setups this is... eze for anyone to get... low cost....an work great...
if i were to ever Diy panels that i could not take apart...an i only got one shot... i would have to go with what i could find like the Licron.. or what other ESL sites sale as coating...but here in fl the air is so wet...90% of the time..if i cant clean the panels ones a year ...i just go bact to the Apogee an Magnepans..
Typically sections not wider than about 8 inches or so as the wider you make them the more directional they become.
Most use many sections of about 3" wide.
I like the 3" wide ones as they don't start becoming directional until at about 4Khz.
I have not tried building anything narrower yet but I have thought about it.
This is why I am trying a electrically segmented stator design now.
I have some 10.5" wide 3' long TIG rod stators that I have made for some bass panels that I have to finish yet.
These will either be run fullrange or mated with a 4" or 5" segmented Midrange/tweeter panel.
Anything wider you may run into a stability issue with not enough tension and/or have to use a thicker mylar of .5 mil or more.
I had a hard time getting enough tension on my 7.75" wide panels using .25 mil mylar, But I did get it to work.
I don't have a mechanical stretcher and I use the heat gun method to tension the diaphragms.
Typically a 12" to 16" wide panel in 3 to 5 sections about 4' high will make you a very nice sounding panel using a woofer of some sort for every thing below about 250hz to 500hz denpending on the D/S (diaphragm to stator) spacing that you choose.
1/16" is good for 500hz or so any lower you need to go more like 3/32 (.093") and a higher bias voltage as well.
But not more than 1/8' or 3mm for a very wide panel.
I will be exploring this in more detail on my new build and will be presenting some solid info on such guide lines.
But those are the ones that you should consider when looking for materials and the method you should choose for construction.
Your D/S to width ratio should be no higher than about 1:100 for good stability.
I like to go a little lower as much as 1:45 or even 1:30 for that extra room for excursion and my smaller panels.
This helps at the lower frequency's to keep the Diaphragm from clipping (slapping) into the stator.
jer 🙂
:hohoho:jer
Youll dig this ,... i know your panels are all open...got be the best sound you can get.....
so how do we get a ML or any panel thats output of like 90db at one watt.. to give wider sweet spot ...big 3D stage...an out off about 95db at one watt....
I have working on the ML panels from 95....
ML found tha 9" wide by 40 1/2" tall panel would have some of the best sound if setup right .....
but if thay went with that panel some would never need a biger panel....so the way thay got the panel to put out less was buy adding cross staders....all there panels are setup this way...as are a lot of other panels diyed an so on.....so we know the way the panels are put to gather is the Mylar is glued to the [back] only... so all the cross staders are on the back ....thats were the glue is...an althe way around...like in the pixs....
so how i did to get more output out of the panels...was just take off staders after the metel was formed so there way less cross staders on the front part of the panel....this lets the ear hear much more output of the mylar...an the sound is much sweeter..an matchs the base driver just like it was a ESL also....
Now some well say... an on paper it may... the front staders have more to do with panels sound.. than just the output..... well all i can say... is if you get any panel of ML part...give it shot....
I think people like Jazzman an others has had the sound from day one... has to be even better ...with there panels setup like the Acoustats with NO..cross staders....on the mylar...
In the pix... of the front part of the panel you can see theres one cross stader in the middel...
the spekar i have working now an sound the best yet... have 3ea are the top an 3ea at the bottem only...
This coaeting has give me the best out put yet......have fun... keep diying ESLs
Here are the Aerius i...
I have had these from the 90s...cool thing.... this pic is when the panels put back to gather after this mod.... it looks like all the staders are there..cant tell there out.......by looking
.An i posted about this mod on the back bar of the speakers at the top..
one more way to cut output....
But on the biger Logans like the Ascent i... it get to much...well if there is ...too much...of any thing...... the stage GETS REAL BIG.....but it just 6 small swres...an you take it in an out......
On the Aerius i this remove of the top bar.. works like a charm...an you can add it back if you
like...
these have never souned better....befor these mods there no way i could live with the sound of the Aeraus...Vary Dark sound....like jim powers of ML told me in the 90s when i cap tell him after he sent me free new panels....thay sound no better than the 1 years old one.... look at the panels we did all we could to turn it off.......have fun
