yeah, I looked at that datasheet when Mr Curl mentioned it earlier: [added emphasis]
interesting choice John, you point out that the input op amp in your circuit doesn't require high slew rate, nor high output current
then you select an op amp which has both - and at a high price in performance specs that might matter
the AD825 12 nV/rtHz noise is speced at 10 kHz - datasheet writers only do that when the 1/f corner is over 1 kHz - and 12 nV is poor, expecting several times that at 1 kHz is worse for audio
noise is consequential in headphone amplifiers with higher sensitivity headphones
I use a 10 kOhm volume pot just to keep Johnson noise low, wouldn't use an op amp that gives noise figure even 3 dB worse
Samuel Groner's Op Amp Distortion measurement paper ends his AD825 section with:
...Not particularly well suited to low distortion applications, and relatively expensive
SG-Acoustics · Samuel Groner · IC OpAmps
lots lower noise fet input op amps exist, not every product can afford the OPA627 but even at the AD825 price level there are options
look at the OPA1641 - 5.1 nV/rtHz, 20 V/us, 11 MHz GBW
normally I wouldn't consider 1 nV/rtHz class low noise bjt input op amps in this position but even they can still beat the 825 on worst case noise with their ~2 pA/rt/Hz current noise and 20 kOhm or less volume pot - OPA1611
there are even CMOS op amps that beat on noise vs AD825 and cost less than $1
Demian, I have been proposing a composite circuit with "good, "audio" input op amp wrapping a outer feedback loop around the TPA6120 - doesn't seem to float John's boat - even mentioning that his buddy Walt Jung likes the topology for audio doesn't seem to help
Supporting cast is getting worse -
What's there to parse?, Nelson is one of the only people here that will face up to the fact that MAYBE the distortions of simple no feedback circuits cause user preference.
I wouldnt be surprised. Few people get to hear systems without some fairly high 2nd harmonic (at least). And, my own experience has been that lay people who rarely even listen to music do not like a system with bass much below what they have always heard -- saying, it has too much bass or it is bass heavy. Sometimes say the same about highs they never knew existed when hearing them for the first tiime. So, designing to others tastes and likes is a disaster zone unless it makes money for you. For myself, I am tired of listening to distortion in 'high-end' systems.
Now that the world is going mobile + small/tiny stuff.... the passive parts are getting worse... esp caps used in sm/tiny sizes. -50-60dB? While the IC's are very good, the supporting cast is getting worse. I dont want to see them used on a high-end pcb where analog is being processed. See
www.AVX.com/docs/techninfo/tantbench.pdf.
Thx-RNMarsh
RNMarsh,
For those people just put on an MP3 and they will be so happy........... I don't think that most people under 50 these days know what good audio sounds like. They are using their phones to play music and they don't own any except for bootleg MP3's anyway. Have you had a chance to get over to Hollywood and go to Amoeba Records? So much new vinyl, perhaps music quality will return to the masses some day.
The question is if the reason and explanation would be that simple. It would be nice if it was that simple, right?
You may try to add distortion (2nd harmonic or any other) to the music by maths. It is not that difficult. Let me know if it sounded "better" then, for anyone.
The second explanation is that the All-Mosfet design is pretty immune against EMI/RFI (no rectification, no demodulation) and the higher distortion is just a result of very simple circuits.
Listening tests of "distortionless" opamps like LT1028 x OPA627 would support my suggestion, IMO. LT1028 is on of those very sensitive to RFI. BTW, AD797 is NOT too sensitive to RFI, though not that immune as JFET opamps.
Yet he's on record as having designed it [the 797] out of one his regs in favour of a JFET part with inferior noise.
When I worked with Walt in '94/'95 on the Audio Amateur superreg series I had considerable difficulty to keep the 797 stable in that application.
I was not able to convince Walt at the time, partly because the 797 measured the best of all the opamp tried.
Later on Walt appears to have abandoned the 797 (in the superreg app) also, but I am not sure which one he is now recommending.
@PMA: Yes the 844 is a well-kept secret in audio ;-)
jan
So it is true that there are secrets in audio 😛 Just following my logic. I don't know much about audio, but there are things I know that I don't want to share. Logically, the experts know much more and may only want to share what is already in public domain.
AD844: CFB, 2000V/µs 😉
I have a plan to use a 3553 buffer, driven by 3554. They are fast but I didn't find current feedback has been mentioned in the datasheet. But I think it is. Not for audio, but why not? Any good comment to motivate me finishing the project? 😀
The 3554 is an old hybrid voltage feedback amp: http://www.datasheetcatalog.org/datasheet/BurrBrown/mXyzywq.pdf
