use any protection and instead relay put a resistor. than the voltage on it use as protection signal that will turn something on/off.
and if the driver is set to a 10mA bias or a 50mA bias then To220 temperatures will be very different.
thanks friend for your answer
i want to conect this protection to my micro project
this three board must be seperat of them
i have 5 amp in one box and i must have 15 protection for those
for every one amp 3 protection:
1. DC protect
2. over curent protect
3. short circut protect
i need 15 optocupler for this 15 protection
sorry for my english
are you underestand?
Nice design sir RIFF, can i have the pcb design of this amp sir?
Thanks!
borbon70
hi apex sir,
maximum how many output pairs can i add to ax14? because i increase bias emiter resistor voltage to 20mv, outputs are little hot. can i increase the dc voltage to increase power.? any changes to make.?
hi apex sir,
Use AX20 schematic and add 2 more pairs ( 4 pairs total ), DC rail voltage with 4 pairs increase to +/-80V and you have 400W/4R amp.
thank u sir for the reply,
Yes it is at same thread http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-92.html#post2758526is ax20 the same as ax14, the topic of this Thread?
#915
AX20 use +/-60V rail voltage, I won't share pcb designs in future.
hi apex sir,
which protect u suggest for ax20 with 4pair 80vdc.?
hi apex sir,
Use protect from B500 or simple protect with NE555.
the link took me toYes it is at same thread http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-92.html#post2758526
#915
fortunately you gave the post number 915.no one answer!
Use "copy link location" with a right click, then left click.
The include the save by "paste" into the post/reply.
- 100W Ultimate Fidelity Amplifier
