UCD 25 watts to 1200 watts using 2 mosfets
LC meter
here more updated LC meter i also made and it works well
small 100uh coil can be found on defective tv or psu
  • LC METER.zip
    LC METER.zip
thanks manoj finally you've shared.
hi guys, i have these cores i think they're E65/62 cores can they work with a IGBT30n60d to produce over 5kw power? I found them in an old ups as inductors.
please help.
hi again mr manojtm
can you please share part list of your amp and swichin power?
it is important beacuse i do not know which of resistor are 1% for example and some of part is unknown to me.
very thanks friend
Hi Hadi,
all resistors are 5% except ** one (1K 1%) you can vary the value ex: 1K or 820 Ohm or 680 Ohm or 560 Ohm or 470 Ohm. lower the value will increase the fsw. NB:keep in mind your MOSFET(low switch ON,100nC and high speed switch) will support the high fsw.
LC value also vary when you change the fsw ex: 500 Ohm resistor L&C will be 33uH & 0.47uF/250v (fsw = @400KHz)
IR2110 pin 5 & 6 connected capacitor is 1uF/100V.(type mistake 10u/100v)
and snubber 47 ohm 0.5W with 100pF/1kv,MUR1560 & 25uH coil is an optional ( it is for EMI reducing)
MANOJ
thanks to manojtm
Hi Hadi,
MANOJ
thanks
and ETD29 have gape or not?
pic of round core used 5KW SMPS
Hi Nano
greetings any idea of core used in smps the round one with yellow tape and what core material please can you help out
warm regards
andrew
