Updated assembly guide
Hi all, here some smallish updates to the assembly guide. Some guys have contacted me with the goal to translate it to german - I have sent the file and they will be posting it here, many thanks in advance!! (sorry don't have the time, the components have arrived and I will be busy packing...)
For example this one :Studio Mikrofonkabel - KLOTZ A.I.S. GmbH Onlineshop
Hi pdul, I used a cable with 6 wires and industrial connectors:
DIN-Kabelstecker, gerade Pole: 6 SV 60 Lumberg im Conrad Online Shop | 733239
DIN-Einbaukupplung, Frontmontage Pole: 6 KFV 60 Lumberg im Conrad Online Shop | 733020
Not sure the pre-reg needs to be removed, but it sure helps with installation.....
Most important is how you route the GND inside the cabinet. I made some comments about this in the assembly guide, that worked well for me. With a preamp that is SO low noise it is important to not spoil the performance elsewhere....
Anybody with a take on interconnects between preamp cabinet and psu cabinet?
Wire? connectors? Etc.?
For the PSU I am using those
ITT 10 A 7 pole
Buy Industrial & Automation Circular Connectors 7 way ITT JC chassis socket,10A ITT Cannon 127039-0022 online from RS for next day delivery.
I have been using those for past 6 years or so.
Pictures of it on MY Paradise tread.
Still nothing wrong whit other ones suggested
Why not ?
They have a slightly more analytic sound then the Dale RS65 i like.
Can you send me a link to those RS65s you like...
Bob
- Analogue Source
- Paradise Builders
