I'm agreeing with madisonears. Here is a link to a subjective live review of the beta version of the MyRef-Fremen Edition vs. a good tube amp.
The FE is now in the release candidate phase and sounding "sweeter" and warmer as it's development progresses.
SO, since we're in the chip amp forum, may I interpret your answer as "Driver Chip" for the sweet sound?If these really are the finest, then I'm of the opinion that the best chipamps perform far worse than the good discrete designs available.
P.S.
As for MyRef, I'm awaiting the parallel version. Both the spike system and current noise have a tone (harmonic noise) to them. MyRef's feedback eats some of that noise. Ballast resistors for parallel would eat some more of that noise. And ballast resistors eat up some crossing noise too. On theory, MyRef's got the win hands down until it comes to the cheapskate output devices, that would improve tremendously if paralleled. Want Parallel MyRef! Got 4 NOS LM3886T saved up for the occasion, but it has been a long wait. Chips don't compete with discrete amp's tone unless you make Parallel chip amp. Of course that sounds a lot like discrete amp with paralleled outputs. So, if parallel LM3886 MyRef isn't doable, perhaps the designers would try Driver Chip, Howland Current Pump with parallel output devices? Far more power and better tone that way, yet similar cost, and probably easier than paralleled chips.
Daniel, Are you referring to something like this?
Hi Bob! Thank you for the updated information.
MyRef X2 Evo-2 (parallel lm3886 howland current pump)
(one channel shown)
And, Hooray!! LM3886 Parallel means quality outputs at last! Might should have started with quality output for less current noise, less spike noise, better tone and enhanced compatibility with modern speakers such as the Statement series. However, since quality output is a major change, do you have any news on how the fine tuning redo is progressing? Is it "Spacious" yet?
P.S.
Experimenting with a fine "Driver chip with parallel output devices" build, might be easier for howland current pump than parallel chip amp. Driver chip is almost plug-n-play with existing MyRef designs, except also incurring a fine tuning redo since using quality output devices needs tuned for less masking, because you start out with the tone already excellent.
Hey Daniel,
Just to be clear if I wasn't - there are two current paths in the MyRef development. The Fremen Edition is being headed by Dario Inserra who lives in Italy. The parallel design is from Sivasankar Chander who is based in India. Siva's haven't been released yet but we are all looking forward to that date. Both designers have shared their knowledge and experience ever since the MR v1.2 days. The future will tell how much cross development develops.
For the FE RC, around twenty builders are in the "tuning" process. We are probably still in the early weeks of a window ~ six mouths. Not a whole lot more has to be done as all who have completed the amp are quite impressed.
I have been following the Statements speakers for years and consider them probably the only design I would consider as a future project (actually have the wood cut for a pair of monitors). With the "Sunflower" design which is also OB mid-range with a fairly sophisticated XO, the FE RC amps are as open and spacious as anything I have owned.
I wont wax glorious on the MyRefs and totally hijack this thread, but your design ideas are truly intriguing and I hope you will become an active contributor to the MyRef development in the near future.
The new RS180 4 ohm alloy cone woofer is higher resolution part at the cost of a greater reactive load. It easily knocks out a solo LM3886TF. Amplifier noises include minor screeching, unbalanced tone of current noise, and loud clunks from the protection repeatedly flipping the mute on and off as the chip slowly breaks down.I have been following the Statements speakers for years and consider them probably the only design I would consider as a future project (actually have the wood cut for a pair of monitors).
MyRef-X2 (the Parallel MyRef) could drive it; however. . .
Since, actually, speakers are the output, let's look again at the speaker.
Quote from Jim Holtz (circa 2008~2009): "The RS180-4 version was selected after evaluation. We found the 4 ohm version of the RS180 had extended bass just like the 8 ohm but with a higher sensitivity which allowed more flexibility in amp selection." How unfortunate. First, that bit about the amp is backwards (or maybe they were talking about a t-amp). Second, the old RS180-4 is discontinued and the new substitute sucks at efficiency--there's no advantage to the 4 ohm load in this case. The fix for both errors is new, unshielded, RS180-8. There will be some crossover work, but, supporting 8 ohm amplifiers, like MyRef-FE is seriously overdue for the Statement Monitor.
Daniel's version of "new science".The new RS180 4 ohm alloy cone woofer is higher resolution part at the cost of a greater reactive load. It easily knocks out a solo LM3886TF. Amplifier noises include minor screeching, unbalanced tone of current noise, and loud clunks from the protection repeatedly flipping the mute on and off as the chip slowly breaks down.
Well sir, the energy to make more trips faster comes from the amplifier--no free lunch. The old RS180-4 was efficient, but the new RS180-4 is less efficient. Beating up the amplifier with the new RS180-4 is pointless, given that the efficiency is not significantly different for the new RS180-8.
Instead of using the new reduced efficiency 4 ohm woofer, the Statement Monitor needs adapted to use the nice 8 ohm woofer, amplifier intact.
EDIT:
On topic of this thread, reducing current noise. . .
EDIT:
Daniel,At least 10years back i tried with this LM1875 that was nothing special I remembered that sound was very clean but something missing.Yes i have played that amp one to one and half year.not bad it was!! but i remembered that little noisy TDA2030A was my good feverish.TDA2030A sounds like crispy but no magic.TDA 2009 have some magic of sweetness in 8Ohm load but very low power, only 6+6 watts into 8Ohm.
I have old Chario Cinthear tower speaker, three way. Dome tweeter and 6.5 Inch mid band is front facing and another 6.5 inch low band is floor firing bass reflex. deliver true flat sound. bass is no deep
I want to go for active crossover system.
A Entirely divergent view??
After 40+ years of 'dicking' with Audio I've learned the hard way (invariably that ones' Speakers are 'at least' 85/90% of the sound produced.
Seriously: Invest in Speakers that do ..Everything.. you want before wandering off on equipment tangents.
I've been involved /responsible for a 'lot' of bespoke hi end AV setups in Clients' homes, typically north of $250K worth, serious coin.
I've learned /observed that electronics ie: Amplification.. beyond a certain quality threshold point makes virtually NO audible difference whatsoever. Speakers absolutely do. Same electronics sound noticeably different on 'alternate' speakers though, despite these being Multi K$ known brand ones.
Can only suggest reordering ones' priorities for best result for $$ /time expended. ..as the First step Buy the best speakers that you can't afford.
Poor? Save up for years if needs be, It's Basic and worth it.
PS a 6.5 " driver is Not even close to providing accewptable Bass.
Bare,
Your comments appear sound and logical. I would ask however, if you can comment on a point of diminishing returns for "Us Poor-folk" for speaker selection/building . I see a two sided coin here where either the speakers or the amplification needs to stay the same in order to hear differences in the other leg.
I would also appreciate your experienced view of using discrete equalizers and/or active XOs to shape the sound of any amp into "sweet" or any other character.
We interrupt this regularly scheduled chip amp thread for fact clarification:
Daniel,
If you are comparing the T/S parameters of the old/new RS180-4, there is no difference in the load seen by the amplifier. Le and Re are nearly identical, and the complex impedance of either, modeled in a vented enclosure, indicates low phase angles at the impedance minima. If you intended to compare the impedance of the 4 ohm to the 8 ohm version, then of course you are correct.
-In addition: I calculate the USPL of the current RS180-4 to be 2.4 dB higher than the RS180-8, based on the published parameters. –No suckage here…
-I use USPL as SS amplifiers are by nature voltage gain devices.
-Finally: Since the vast majority of quality amplifiers are 4 ohm capable, I see no reason to fix my ‘error’ in the Statement series designs. –I’m sure that was just an unfortunate choice of words on your part. Certainly I have 8 ohm designs on my site. The Singularities are a high sensitivity 8 ohm full range design, and would work very well within the electrical constraints of a chip amp, as would the TriTrix design. Unfortunately all the Statement series are 4 ohm designs.
Sorry for the interruption, and may I suggest any further discussion on this topic should be taken to another thread…
Curt C
We now return you to your regularly scheduled chip amp discussion…
The original poster did specify a level frequency response and very spacious sound stage. He also gave an example of a singleton input amp that is very difficult to beat on those two features (if one is also using regulated power). He also mentioned that LM1875 was insufficient in comparison.
Now he wants a more powerful amplifier to sound just like his 6 watt singleton input amp (except much more powerful) and he wants it to be a chip amplifier. Tallest order ever. MyRef-FE is a close match to this request, if one has 8 ohm speakers. Driver Chip Amp with a buffer or pre is a close match if one needs to drive 4 ohm speakers.
However, most other options are in or near prototype stage thus low availability.
Thank you for the response.Since the vast majority of quality amplifiers are 4 ohm capable, I see no reason to fix my ‘error’ in the Statement series designs.
To drive a 4 ohm speaker, you're looking at double the transformer amperage, double the heatsink size, and double the thermal interface via doubling the output devices. This meets your "Quality" clause and thus, your statement is not actually erroneous. My apologies. However good your idea is, there is low availability of home amplifiers that drive 4 ohm loads gracefully, safely And in high fidelity. My thoughts were about availability. I also worry about amplifier shoppers being informed or not, since overload risks can be problematic.
Since we're discussing chip amplifiers, how do you feel about an 8 ohm Statement Monitor for the MyRef-FE? Now, that would be an excellent solution. Please?
I support your 4 ohm designs, especially the effective double-woofer designs for moving compromise out of the loudspeaker and into the amplifier where it can be easily dealt with by sturdy design. For me, personally, that's not a problem since I have changed to entirely 4 ohm capable design.
However, breakage or even fire could result if the amplifier is not especially prepared for 4 ohm loads, and therefore, assuming that 4 ohm loads are usually okay for most amplifiers could be hazardous. Unexpectedly pulling double the current for 2.4db will not go well with a random choice of home amplifier, since the standard spec (and builds) are 8 ohms.
P.S.
Earlier wasn't comparing difference in load between old/new RS180, but stating an EMF difference between high resolution alloy cone woofers versus more ordinary woofers. The LM3886 is borderline to drive a cheap 4 ohm woofer, but RS180-4 kills the chip. Neither would work for very long term (unless given 4 ohm specific re-design), and both loads end in destruction so perhaps that point literally fizzled.
EDIT:
Most shoppers and builders are assuming that Overture series and some other chip amplifiers are entirely quality design because the chips DO contain top-notch predive units; however, most people seem to have ignored the fact that the tiny enclosed outputs aren't stronger than something like a BD911 for example (strong output devices can't fit inside the chips). Even with larger transistors, consuming the insides of BJT output devices is exactly what heavy loads will do. When enough of the interior insulating layer is eaten away, a spark is conveyed and then the stench of burning electronics. Some amplifiers may last 6 months to a year before the damage of corrupted output devices becomes severe enough for burnout. That is more likely to happen to a chip's small output devices, but any size can be damaged, including discrete amplifiers made for home use.
Ultimately, it is your choice as a designer to determine how much trouble 2.4db is worth.
Compare:
Waste heat in the transfomer
Waste heat in the CRC resistors
Waste heat in the ballast resistors
Waste heat in the heatsink
Using RS180-4 and RS180-8 for the comparison, output power has been crippled by the RS180-4's load causing output power to go many places other than the speaker and this waste may result in much more clipping. Given the many losses, surely the 2.4db advantage is not in effect during maximum output, and thus the 4 ohm version has uselessly abused the amplifier. At maximum output, you'll find the 2.4db worth of watts has been outputted to the heatsink, not the speaker.
The above is regarding single woofer speakers.
I have no complaint about double-woofer speakers requiring more current to move twice the cone area.
Hey Curt, For me - this discussion is too interesting to just drop. Are you aware of an appropriate existing thread that addresses the topic? My interest is centered on the MR FE/LM3886 but the 4 Ohm/8 Ohm information in the last few pages appears a logical next step to optimize the marriage between the MyRef family and speakers at the quality of the Statements family.
If nothing exists, I'll gladly volunteer space on the FE integration thread.
Actually love Curt's speaker designs.
As a matter of public record, I love Curt's double-woofer designs, and a diyaudio.com search will confirm that I have a long history of recommending the Statement speakers. . . and usually as motivation for building extra sturdy amplifiers. For this reason, my 4 of NOS LM3886T's are still waiting on MyRef-EVO2 boards. It has been a long wait.
On topic. . .
This thread is basically about soundstage of audio amplifiers:
Invalid compensation produces "pancake" pattern (not long, not wide)
NatSemi chip amps produce "alley" pattern (long, not wide)
TDA7293/4 chip amps produce "stage" pattern (wide, not long)
High Fidelity Class produces "arena" pattern (both long and wide)
The above can be observed with one/each speaker. The chip amps can be nested, composite or current pump to incorporate a small signal amp in the feedback loop, and if the small signal amp has the opposite pattern, then the result is a high fidelity class soundstage, (both long and wide). It is also possible to alter soundstage at the power circuit, which is working with the speaker negative instead of the speaker positive. Or, a very faithful Driver Chip Amp can be used with a high fidelity preamp for somewhat similar results.
Now, match the available excellent speakers to the Available excellent and extra sturdy chip amplifier. Oh dear! Well, the other way to put an end to the long wait is an 8 ohm Statement Monitor to support the MyRef-FE.
On topic. . .
Can you consider LME49830 + external pair of fets as chipamp? If yes - then it is a go. When I p2p-ed it, I was surprised with the excellent sound. I run it with IRFPs, 2 pairs per ch, 700mA bias. About OPA549 - it sounds sweet with additional gain stage, and the chip running at low gain, like 3x.
Maybe 12AX7 in front of OPA549 or LM3886 used with low gain could make it sounds "sweet".
However good amp (and preamp) for quality stereo should be fully transparent without no coloration at all with a decent BW and what has to be "sweet" is your audio source.
Wadia are making "sweet" DACs. Pioneer Legato Link is not so advanced but might be an inexpensive item to get (it's using simple cubical spline for interpolation). Lampizate it with 12AX7 that is it.
LPs do not suffer dither & interpolation artifacts sounds clean and natural with good tube phono. But NOS LPs priced insanely noways thanks to Philips aggressive (if not call it bloody) marketing of "superb CDs" in the recent past.
- Chip Amps
- Which chip amp can play sweet sound, need your experience
