Which chip amp can play sweet sound, need your experience
Hi friends
I want to build an active crossover sound system with chip amp for my living room. I know others discrete or tube amp sounds better then chip amp but chip amp is easy to build and compact and some chip amp sounds really good.I am puzzling :hypno2:to select by which chip amp i can starting.😕 I have already in my junk box LM3886, LM1876,TDA2009A,or i can manage any part no.
Sweet sound is more a function of the layout - I have experience with LM3886, LM1876 and others - they can all perform well so long as the circuit and layout are done right. So decide how much power you want and choose accordingly.
Thanks for quick reply Mr abraxalito. My need between 30 to 100w/Ch. LM3886 have many lay out in the internet can u suggest me which one can i picked up?
*Can" play sweet sound? All of them. Easiest to tune any way you like including sweet sound? LM1875.
My favorite trick is LM1875 Parallel driving a double woofer (4 ohm) speaker such as an MTM. That gets you the power for realism, the big current and the impact (that sort of speaker also gives lower LE figure for half the peakish and a half price inductor) and you still got to use the easiest chip for nice sound. If there was a quick pat answer for easy economical high fidelity audio, that's it.
The LM1875 comes closest to a "tube" like sound, the LM3886 closer to a "solid state" sound. However you can change it to a partial current feed and then is sounds like a tube amplifier without the distortion. What do you want the sound to sound like and how loud do you want to go? Stating 30 - 100 Watt without knowing your music, loudness requirements and what speakers you are going to drive is not enough information to give advice.
I would run a LM4780 in Parallel to get plenty of power from a single chip.
LM4780 has two LM3886's on board.
You should easily be able to get 100W out of that.
Einric, thank u first to reply, i think high power is not necessary for sweet sound reproduction.To reproduction of sweet sound needs others things,what is the others things and where i will get it that is the question.Why some amp sounds sweet? what is the magic behind this?
Daniel,At least 10years back i tried with this LM1875 that was nothing special I remembered that sound was very clean but something missing.Yes i have played that amp one to one and half year.not bad it was!! but i remembered that little noisy TDA2030A was my good feverish.TDA2030A sounds like crispy but no magic.TDA 2009 have some magic of sweetness in 8Ohm load but very low power, only 6+6 watts into 8Ohm.
I have old Chario Cinthear tower speaker, three way. Dome tweeter and 6.5 Inch mid band is front facing and another 6.5 inch low band is floor firing bass reflex. deliver true flat sound. bass is no deep
I want to go for active crossover system.
Daniel,At least 10years back i tried with this LM1875 that was nothing special I remembered that sound was very clean but something missing.. . .
Maybe the NFB cap (if that's missing, so are your dynamics)? Maybe the input load too light? Maybe the negative feedback current too heavy? All of those occur with common/free/datasheet designs. OR, with the Quasar Kits #50 (K50 kit), the feedback current is insufficient (or possibly the feedback shunt current is too light).
SO, try this:
330uF power caps directly at the chip (range 220uF to 470uF) and of course you'll want some bigger capacitance added nearby.
One 4.7uF 250v cap from v+ to v- (noise filter)
33nF polyester caps for power decoupling right at the chip.
Feedback resistor in the range of 47k to 100k
Feedback shunt resistor in the range of 2.2k to 3.3k
NFB cap in the range of 120uF to 470uF
10k input load resistor (range 5k to 12k)
3.3uF input cap (range 2.2uF to 4.7uF)
There is ranges of values. I'd suggest to experiment within the range and see if you can get LM1875, LM675 or the similar 5 pin chips from ST to have a very pleasant sound. LM1875 doesn't want gain over 48 (45 and less sounds better than 48), LM675 doesn't want gain over 15 (LM675 can boost a headphone amp), and most of ST's don't want gain over 23 (compensations sealed inside little black chip). So, if you've got Computer, digiplayer or iphone source, use LM1875 for its big gain capacity. The smaller your feedback shunt resistor the bigger your NFB cap needs to be (examples: 120uF+3.3k, 220uF+2.7k, 470uF+2.2k, and nearby values work fine). Figures are approximate. Basically I'm just saying you do have options to explore and these options all sound different.
Chips don't make just one sound. They do whatever you ask.
The chip amp doesn't make any sound... that's what the loudspeaker does.
You might think about your question. I don't believe that you are asking the right one(s).
You need to think more in terms of how much power you need, and the distortion (and what kind of distortion) will be produced at low, medium, and high power outputs (relative to what the chip amp is capable of). That, and the noise (from the layout of the board and power supply) of the amp are about all you should be concerned with.
Think about your loudspeakers and the room they are in. Executing the loudspeaker and its crossover correctly have a large influence on the sound. These things are vastly more important with regards to "sweet sound" than the amplifier.
-Charlie
He said Active Crossover, and the TDA2030A (and similar from ST) does have some crossover examples with its documentation. If given an Active Crossover, it seems like whatever fine job you do on the amplifier can be swamped (made less important) by RC and EQ distortions that are usually much worse than passive crossovers. Good luck.
It isn't especially low power in bridge config.
The magic sweetness, like TDA2003, is singleton sound. Amplifiers that may sound similar include Singleton input, NTP input, SSA input, and many tube amplifiers. On all of the examples, regulated power, K-multi power, or capmulti power is suggested, especially for singleton.
Perhaps you already have a good power amp and it needs a Singleton Preamp or a Triode Preamp to make sound like you expect?
It is not expensive:
MooseFET Preamplifier
Try it with:
IRF510
Nichicon ES 0.47u input cap
Elna Cerafine 16v 47u // Nichicon ES 1u output cap
Multi-Turn trimmers
Low ESR caps, such as Panasonic FC
Big soundstage and good tone is not necessarily about singletons and triodes. It is more likely to be related to whatever is most helpful to the source device. A Diamond buffer can do it. Have a look at these:
http://www.diyaudio.com/forums/solid-state/130952-improved-diamond-buffer-design.html#post1660583
For power, I'd choose OnSemi MC7815, MC7915 regulators, since excellent quality power is the other half of the job.
I'm really surprised no one has contributed this yet, so I guess it's up to me.
The MyRef series of amplifiers, originally designed by Mauro Penasa and offerred by him here for DIY, is perhaps the finest implementation of power chips available. Do a little research, as there are several threads dedicated to it and its most recent incarnation as the MyRef FE developed by Dario (ClaveFremen).
I have owned massive tube amps and multi-thousand dollar power amps, and this little amplifier, when properly constructed with quality components, equals or surpasses all of them in almost every way. It is easy to build, inexpensive, reliable, efficient, and sounds beautiful: sweet, spacious, accurate, detailed without brightness or fatigue.
The basic design is readily available for private use, and several group buys have allowed many happy builders to purchase PCB's or entire kits. The configuration I currently use is identical to what you have described, with the monoblock amps directly coupled to active xovers, all in the same chassis.
Peace,
Tom E
The MyRef series of amplifiers, . . . sounds beautiful: sweet, spacious, accurate, detailed without brightness or fatigue.
Thanks for the review!
Yes, "spacious with good tone" and sufficient power are what he's looking for.
So, your answer is very good.
Perhaps the current pump topology, and pedantic attention to component detail provides an "out of the box" hi-fi experience. However, the constructor must avoid substitute parts and also is required to follow known successful examples for power and wiring layout. . . so as to achieve the documented outcome. Even so, I think it wonderful that the majority of the fine tuning work is already done and already documented.
MyRef-LM3886T: Much faster trip to hi-fi and much less financial risk to use known good.
P.S.
Given this news, perhaps it is time to exhume/reboot the Nested LM1875 project, which isn't a current pump like the MyRef, but does have a small signal "pilot amp" (nested pre) like the MyRef. To compete on current, we'd probably have to do a parallel amp, which may be more complex. Like Ataul pointed out, the LM1875 by itself is an "almost" home run but Not competitive to the singleton chips (TDA2009, TDA2003) for "Spacious" soundstage feature. We need to widen that a bit, per each speaker and that feature must be provided by whatever pilot/pre amp is chosen.
Such work has already been done for the MyRef-LM3886T.
