I have a curiosity:
are the same output devices employed on the first X Series the same on the later X.5 and XA.5?
thanks
I was thinking of buying either the X600.5 or the XA200.5 if I could find them used would be even better.
I would pair them with my B&W 800Signature.
I currently own the X250 which is a very nice amp, and I was either thinking of trying to build one myself first and then once I had fun buying one of these two beasts or just skipping the fun part and go into serious stuff!!
Also if anybody knows, what is the difference between X series and X.5 series.
I have read that the latest X.5 sounds significantly better.
What is this due to?
plenty of info in last several months
find XA white paper on PL site
where can I find this paper?
I have looked on Pass lab site but couldn't find it!
Or maybe http://www.firstwatt.com/pdf/art_leave_classa.pdf
But, I think the answer is More Bias!
maybe between X.5 and XA.5 there is more bias.
However I think that between the X and X.5 series the front end must be different giving equal output stage, this is my guess...
Well, I wonder why you are interested in those two models. One has double the bias and 4 times the power of the other?
Maybe the article ZM is refering to is this one:
http://www.firstwatt.com/pdf/art_peanut_butter.pdf
Also, isn't one a complementary follower ouput and one and version of the Aleph type output?
One is complementary on the X/X.5, I thought the XA had the same topology but more bias, but it makes more sense that difference would also reside on output stage.
I doubt that it is like the Aleph though!
Since I have the X250 and I think it is a very nice amp and I have read that there is a LOT of difference between the first generation X250 and the X250.5 and also that the XA250.5 sounds very different from the X.5 series, I am trying to understand what are the major changes that can be attributed to the sonical difference between these models.
I know there is a different level of Class A to begin with between X.5 and XA. However what are the changes from the X250 and the X250.5 for example and is the XA200.5 the same topology as the X.5 series but given a different bias or there othe major circuit topology differences?
XS is the best sounding of Papa amps , we can see the physical differences , is the topology same as XA with bigger hammer ..?
Seeing and hearing the XS models is something else ...!
A little off topic, but I would interested in listening to the XS as well.
I am assuming it is similar to the XA but with a linear regulated PSU, correct?
Does anybody know if it uses a series regulation or a shunt topolgy?
Just giving more thoughts to it, I am sure it is series regulation as it would be impossible to dissipate an oversized "Class A" power supply for a Pure oversized Class A power amp giving that the heatsinking capabilities are the same as the output power section🙂
X250 - older generation UGS based FE , follower style OS with mosfet bias gene , 4 mosfets in OS quadrant,no SE bias , 2x38-ish Vdc PSU
XA200.5 - newer UGS based FE , follower style OS with shunt reg bias gene,7 (or 8) mosfets in OS quadrant,SE bias , 2x34-ish Vdc PSU
type of PSU is least interesting thing in XS amps .
type of circ , with heavy bias , including SE bias , is preventing use of any reg , except possible for FE (which is pretty irrelevant)
It looks like a lot of improvements have been made which would explain the wide sonic difference.
Thanks for the clarification.
I didn't even suspect that the 250.5 would use more MOSFETs at the OS.
Regarding the latest FE UGS design.
If I don't recall wrong several succesfull attemps were made to design the clone, I am assuming, that was related to the first generation.
Is there any design for the lastest as well?
Moreover, when you talk about SE biasing, I don't quite understand how it is achieved.
When I think of SE Bias I can think of the Aleph style where the curernt source on the top side biases the follower.
I have read the paper you guys have linked but I don't quite get how SE bias is applied to a push pull.
Is there any reference on the DIY to this subject?
Thanks a lot.
oh I see. However it is using a regulated PSU looking at the big enclosure deidcated to the supply section.
Also recall Nelson mentioning several time that regulated power amp sound better overall although lack of reservoir.
If you can make the regulator as big as the power amp I would assume you would get the benefits of both world which in my little experience cold possibly make a significant positive sonic difference at a price of bigger heat dissipation and more hardware.
- output devices on X -X.5 and XA.5
