100W Ultimate Fidelity Amplifier
hi apex sir,
i connect the vu meter to ax14, the three lights permanently on. why is that.
supply voltage to the amp 50-0-50vdc.
here are some images.
Is this your PCB, there is another version with -HV suply.
hello frineds AX-14 is working but i am getting noise in the music
Hi Sharavanth,
You need to post pictures as Apex said and measurement, if possible with wiring connection, otherwise unable to comment without posting your work, However see attached picture for correction, hope this will help.
