CoolSo the big disasters is in fact not so big at all
R27 (29) is 120 ohm.
Ok and Fc = 1/ 2 pi RC
Using only one 4700, we get 0.28Hz... not so bad right ?
Thank you JoachimRicardo, you can use 2200uF.
Why the choice of 2 x 4700uF ?
??Passive RC filtering has it´s merits. One is very good transient response or should i say slow response.
Very good transient response.... not slow right ?
No, passive filtering is slow. Thats the name of the gave.
I have noticed quite a big improvment in using a second comon mode coke after the pre regulator
For the beta I had just one trafo and 1 board as drafted a while ago
this won't be the case for the V3 build
No, passive filtering is slow. Thats the name of the game.
Thank you again
I do not see placement for C91 and C92 on the board... Guess these filtering/decoupling caps for the opamp psu lines proved irrelevant right ?
yes, I ran out of space, and since there is one cap there and the PSU caps quite close I took that risk. proved to be fine.
Big $1M question
I am really happy with my V2 Paradise. (Not big secret is it?)
Now waiting for the V3boards I am thinking about really pushing the boat out and use the best components I can get without getting over the top. I think the FM type caps are fine for the job as an example
Now my tanking is V2 sound pretty good as it is and is going to be difficult to make a big difference.
So, considering the law of diminishing returns, where is the best place to throw money at it?
Apart from supply and pre regulator (I am thinking R cores Trafos and big multiple common mode chokes) would it be worth paying attention to the 120 Homs resistors on the mirrors?
Any thoughts?
Any thoughts?
In my humble opinion, using the best RIAA components and spend a lot of time matching them between the channels, and also the transistors of the input stage, should give the biggest gains....
glad you like it - we are at 265 sets (!!!!!) right now..... group buy will be closed today....
Big $1M question
Any thoughts?
RIAA parts and matching (caps and resistors) also matching of the input stage and film bypass capacitors and bulk capacitors on the PSU.
If you are powering it with battery, good quality there will make a significant difference (same as Transformer if you are using one).
Also quality on the OPAMP should make a difference. I would recommend it to replace the OP AMP with a discrete module.
