Offline full-bridge SMPS… need help
car smps
It would be easier to help with problem if you would provide schematic of your design
along with transformer contruction details,Your winding of transformer might be wrong.
how about this shematic?
i creat this one
when i conect battry cable the red led turn on
the mosfets is hote and exit voltage is +-5vdc
i use 4 irfz44n mosfets
can you creat this one?
thanks
The red led is connected to feedback(output of error amp) and will turn on red led when you apply power because of the way it is connected,look at P1,R13 connection and R14.I think if you adjust P1 you will get the red led to turn off(has nothing to do with why your supply does not work.Visit the website I provided and all will be explained ,Start with the correct core for the power requirements and wind it according to instructions,test the inductance with a VOM that has an inductance feature,fed a signal into the primary and check secondary signals.Refer to info at ESP website on checking transformers before mounting.Whatever control IC you use you should read the datasheet,check block diagram of internal circuit to understand its functions.Don't copy a design unless it has been proven to work and a proper PCB is supplied but if want to learn design in stages and check each one, start with control IC first(only requires a few components to function and you can do this on a bread board)apply feedback and check outputs to see the PWM signal and make sure it provides the correct outputs.Once you have the control part working the rest is cut and try to obtain the power you need(use dummy loads)only connect amp when all is well.
Thanks for your reply
You doin best for me and i say very thanks to you my friend.
I see your web site
That smps work with sg3524
I try to find some think in my smps site but the site languich is turkish and main pdf file is rushen maybe.
I dont know this languich.
I try to find smps with tl494 because i have meny of them.
In main site of may smps they use irfz44 and etd 39.
I try to confige red led with pot1 but it was not work.
Can you advice to me one shematice of this topic?
Thanks my dear friend
Have a nise day
I searched for high temperature tape for myself about a month ago. This was the best deal i found. But i did not buy any yet. I was also thinking of using plain clear packing tape. It is $1 a roll 2“ wide and made of mylar.
http://www.1stmaskingtape.com/Blue_polyester_masking_tape.php
Blue Masking Tape can withstand temperature up to 400°F/204°C. It is packaged in a 3" core and is 72 yards long.
1/2" wide x 72 yards $5
Green masking tape is made of 2 mil thick polyester and 1.5 mil thick silicone adhesive. It can withstand temperature
up to 400°F/204°C. It is packaged in a 3" core and is 36 yards long. This is our most popular powder tape.
1/2" wide x 36 yards $3
Red masking tape is made of 1 mil thick polyester material and 3 mil thick silicone adhesive. It can withstand
temperature up to 400°F/204°C. It is packaged in a 3" core and is 36 yards long
1/2" wide x 72 yards $8
P.S. Mylar is a high temperature plastic.
There are many tapes that can be used, I just use the 3m brand and you can also use double or triple insulated AWG or Litz wire with outer cover.By the way 4mm thickness a layer eats up a lot of bobbin area,less room for wire,windings are futher from each other could add to leakage inductance and capacitance.
