JA Pre and MyRef - FE Integration
Squalor, The 30VA 15+15 should be worth a try, but a message to stantontin@gmail.com will get you a direct answer.
I don't want to lead anyone astray by suggesting anything more than a bare pot is needed for excellent sound with the FEs. An active preamp and/or discrete passive attenuator is only intended to be an option for those with speaker or source difficulties/requirements. Remember, I went through the entire beta process with a bare pot.
If a separate unit is desired and cost is a factor, I highly recommend Uriah's Lightspeed or similar design. Its acoustic performance is very close to its big brother. In fact, when I suggested to Uriah that I wish he could design a Lightspeed with an on-board power supply - he laughed and said "that's what the Lighter Note is" 🙂 The advantage of the extra circuitry in the LN is the ability to more accurately dial in its operation to match any given system. That's a great feature but not a necessity.
For power I have always used a leftover 5V wall wart plucked from the pile. (I'm sure you have a collection too) SoIL4x4's suggestion for the regi-reg is something I might try in the future.
So on picture 2 of the 5 you just posted, that is Uriah's LDR correct ? That's what I have. Which pot is the volume ? Is the other pot the balance ? Is the balance (in this case, LDR) not for panning left to right but for tuning to find equal volume for both channels ?
I thought I read somewhere that a switching PSU like in a wal-wart is not as good. Also, I suppose we should only say Lightspeed when talking about the George Stanshef (sp ?) version ?
Back to the JC-2 (or should I call it the JA pre so as not to tick off Mr. Curl). Isn't it able to make more SPL than a B1 or a bare pot ?
You know by now that I'm kinda dense so please help me wrap my mind around this. A bare potentiometer adds a bit of it's own sound signature because of it's wiper material and construction. It's why some people seek out pots by Nobel or Alps. A stepped attenuator makes a cleaner signal because it used fixed resistors of decreasing values instead of a wiper. A LDR uses Silonex light resistors to control input signal, the pot is not in the signal chain so it is very clean. The LDR pot does not need a extention shaft, it can be mounted next to a transformer at the front of the chassis. Only leads from the LDR module to the amp and input RCA's need to be short and high quality. The Silonex light resistors must remain cool during assembly and use. A person could use a LDR module in place of a Alps 27 pot to control a JC-2. A JC-2 only controls volume if one adds a volume pot, attenuator or LDR at the front end of it. Otherwise, it's just a input signal booster. A Pass B1 (or Salas DCB1) in basic form does not control volume and has (no gain) unity gain. Are any of these statements over-simplified ?
Why do you think so many people are on the DCB1 band wagon ? What does it do ?
Yes, that is the Lightspeed.The big pot is volume.The small one is balance but it only operates within a small range. It should probably be called a "centering" pot as it does not effect the volume overtly.
There are probably beter ways to power this, but what I have works for me. I got the Lighter Note before I had a chance to investigate.
Yes, the only reason I bought the JC-2 was for the gain. I have low efficiency speakers. I like my Big Band music loud and screaming , thus the need for some gain
You are correct in all of that. It's also why I recommend that single pot (again Dario's discovery) in the picture. One quality pot is much cleaner and has fewer potential anomalies than any collection of resistor, caps, diodes, ICs and such IMO.
Correct again. Take a look at the integrated thread to see that exact configuration. The LN is acting as the pot for the JC-2. Very good results but definately overkill.
You will have to address this last part to someone else - I have no experience with either.
Hope that helps.
Man, is that not the ugliest post you've ever seen?😱 I dropped out of art class!
Nah, it was colorful.....and helpful. Andrew's was too. I'm going to put my DCB1 on the back burner. I may join you guys later in this thread but for now I will watch from the sidelines. My C-note just got spunt on new IC's for the FE. Along with that order I'm getting some Caddock goodness and even Susumu RG20 for my R12.
Since you've been so helpful and offered me your couch durring my WAF issues I'd like to do something for you. I've got something for you to try at C13. Russian 1uF K75-10 ! Shoot me a PM with a address and I'll drop them in the mail for you.
inadequate Source like the headphone out of a smart phone with 6 meter RCA cord would present a weak signal to a amp ? Same headphone out to a DCB1 to the 16 meter interconnect sounds detailed and effortless ?
Headphones are a Receiver. They recieve a signal from an interconnect.
The Smartphone is, if I understand correctly, a Source component. It sends a signal to an interconnect.
No gain but maybe a 4V line level signal ?
4Vac from an active buffer fed with +-10Vdc is asking quite a lot. You are going to be in quite a high proportion (about 50%, or -6dB) of the maximum capability of the buffer and that is normally a high distortion region of operation for a Single Ended ClassA amplifier without feedback.
With today sources a pre with gain is rarely needed.
That's why so much people use passive pres with success.
But the insertion of the pot in the connection between source and power amp affects impedance presented to the power amp possibly affecting frequency response and dynamic.
A buffer, like the DCB1, helps presenting a low impedance to the power amp and since it's unity gain is, hopefully, more linear than a pre with gain.
Here is a preliminary shot at some parts substitutions from Dario. A version based on hands-on experience will follow in a few weeks.
......but all that Caddock would cost a fortune, I would probably use them only for LR0 and, maybe, LR01.
LC0 should be also important and I would use a Amtrans AMCH or , at least, a Wima FKP2.
Looks like it will be another fun ride. All suggestions, theories and opinions (about the pre 😉 ) are welcomed. I'll do a cost estimate of this package and post it shortly.
Great, It will be interesting to hear your impressions. Make sure you pay attention to all the transistor numbering/markings. I had to start over cause I didn't. Everything is pretty straight forward. Double check that there are no cold solder joints before powering up.
Good Luck.
