Photo Gallery
My tube. 3 6Í2Ï+4 6Ï3Ñ. Stereo 2*16W.🙂
Jadis 30 clones .. Audio8 boards
I built a couple of these . Used Tango (ISO) transformers I picked up in Tokyo recently
The boars come from audio8 they could be smaller .. I used the provided (huge ) power supply boards in one but did one on a tag board on the other.
I think Iwill provide some balanced inputs for them as I am using long lines.
KEG-EAR AUDIO AMP
6L6-KT88 based amp, UL-Triode selectable. 60 watt Hammond 4.3k output iron. PCB is toner transfer method etched in a sink, brass eyelets used for all wire and underboard caps. worked with low cost 6P3S Russian 6L6 to KT88 tubes. 6550=C= were the best to my ears in triode mode. LED bias monitors on front to indicate a bias shift or bad tube. Oak chassis with 10 coats of tung oil.
