@crazymechanic s ground and main ground should be connected to main psu ground
@Djnits pls post photo something is wrong on your step drive high side negative rails is keep triggering
@ryanda 1n4148 is not good replacement of BAV21 use mur120
sir irvynejay here the pic of my h900@crazymechanic s ground and main ground should be connected to main psu ground
BF421 is PNP transistor, use MPSA92 insead BF421 not MPSA42 (NPN) !
thanks sir apex, posible it's the cause of my problem.BF421 is PNP transistor, use MPSA92 insead BF421 not MPSA42 (NPN) !
Djnits yes its possible because you use npn instead of pnp
don't forget S ground and main ground connected to main psu with separate wires
And don't forget wire jumper.
thanks sir irvynejay and sir apex for your adviceDjnits yes its possible because you use npn instead of pnp
hello sir apex and irvynejay still the same my problem, i had all ready change the transistor, of ksp92 PNP, please see my attach pic.And don't forget wire jumper.
thanks for your responce, but i had all ready double check the pcb sir, not posible the direction of sfa1603, if i make to reverse this no problem?can you pls check you fets if its not shorted,, pcb pattern possible for short
Regads
comulator (fmxg12) diode is correct position high rail only trigger when step is working at high gain there's wrong something with you parts
gate voltage is too high make sure fets is not busted
thanks sir jay, i had all ready solve my problem w/ you help, there's a problem w/ my circuit at mosfet. two thumbs up sir jay and apex thanks.comulator (fmxg12) diode is correct position high rail only trigger when step is working at high gain there's wrong something with you parts
thanks irvynejay, and i want share this problem, to help some diyers to be careful of there project and double check, my circuit its look good or no short, but when i check it by tester totally short circuit, please see my attach pic. thanks w/ the help of sir irvynejay and sir apex,ok good to know that ,,have fun Bro
thank's Irvy,..my h 900,.. transistor mje 340 and mje 350 is hot.,.my rail voltage is..80 40 0 40 80 VAC,.whats wrong for this?@crazymechanic s ground and main ground should be connected to main psu ground
Nothing wrong, MJE340/350 work in class A and disipate 1W without signal on amp input, use heatsinks for MJEs.
thank's for sir apex..and now for triple darlington where is the better,..in base i'm put resistor 3,3ohm or without resistor..Nothing wrong, MJE340/350 work in class A and disipate 1W without signal on amp input, use heatsinks for MJEs.
- 900W H-class PA Amp with Limiter
