JC-80 eBay PCBs & Power Train
Chris, where would you take the AC measurement for the impedance change? At the amplifier's line input/R2R shunt ladder output?
The theory (to be tested) is that the volume control (assumed to be at the front of the signal chain) and the active electronics' input (assumed to be next in the signal chain) form a voltage divider. If both channels' impedances are the same, they'll have the same voltage at the junction of volume control and active electronics for both channels.
All good fortune,
Chris
All good fortune,
Chris
What type of signal would you pass into the amp to test? Regular music or test signal of some sort?
Do
Better News
JC-80 apparently safe; house still standing yesterday. 47k acres scorched and fire still only 10% contained. 1000 firefighters on the ground with 100 engines today. LOTS of winged water tanks flying around.
InciWeb the Incident Information System: High Park Fire
We will prollyNot be working much on audio for a while so please work out all the issues so ole Wolfsin can build clean JC-80 next Winter :D
Here is the line amp portion:
