SSLV1.1 builds & fairy tales
Joined 2009
Salas could you help me how to calculate the ripple? knobs: amplitud 5mV/cm & timebase 0.5us
Without bipolar BG 100uF 50V connected at the output sense + & sense- I have the same ripple, it's OK?
I have to change also the IRF610 to decrease ripple?
P.S. I'm like a boy playing with a new toy (scope)
The DMM is not so reliable to test them, especially, if you want to reuse something in a circuit.
I use a 9V battery between G an S to turn them on and then short the legs with my fingers to turn them off. Put the DMM to check continuity between D and S.
This is no the most sientific method, but works for me.
Maybe other members can suggest a better method.
diyAudio Chief Moderator
Joined 2002
This does not look like ripple. Looks random. As it is set, turn off the reg, to see what is residual pick up or isn't.
