900W H-class PA Amp with Limiter
not working
Hi could someone direct me to solution, I have checked the pcb for error found none, double checked everything, voltages on bias are good, 1.8v on collector-emitter on bias transistor and so on, but when i switch the device on from the start everything fine, even the waveform comes ut just as nice but then when i make the input signal higher like some 0.7v sine wave about 1khz the output trannies just get opened and fail with sparks and smoke, basically what i am dealing with is that the base voltage of the output trannies just suddenly gets high and opens them and they just blow, takin sometimes some irfs and the driver transistors mje 15033 and 34 with them. Could someone give me some advise?
Thanks in advance.
Thanks in advance.
Use 150R/10W resistor instead primary fuse for test amp, and post pictures...
Powerfull PA box
Sorry for the bad picture quality itš from a mobile phone.
Hope you can see if there is something wrong in the pictures with my pcb 🙂🙂
Thanks for help in advance.
Here you are!
plz.... send me h900 psu measurement........... & any speacker protection ckt...............
I hope that this wouldn´t be your first audio device... Hope it is at least fifteenth!
  • APEX H900 SCH (1).pdf
  • APEX H900 SCH.pdf
    APEX H900 SCH.pdf
  • Text Document.txt
    Text Document.txt
no i am newly start h900 ............. so any pre amp. ckt.. for this amp.......... pls ... sudgest..........
That is not so clever,to do an amplifier in H-class 900W as a first project...you might get in a lot of trouble and not so many answers. It would be much better for you to do APEX AX12 or APEX D14 or something ike that. They still have a lot of power and they are not so complicated to do. When you finnish it connect two by two in bridge and there you are-doubled power amplifier!
Input gnd must be connect to psu gnd... post picture with input wireing.
hello sir apex i had allready finish my project h900, my rail voltage is 66 47 0 47 66vdc, offset .4v, idling .7v, sounds very nice, but my problem is Mv- 47 cannot inter the diode sfa1603 going to collector of 2sa1943, it takes supply from hv-66, so the other side is -66 collector, and the other side is +47 collector not balance and very hot after 1 song, what would be the problem
Best regards
