Marsh headphone amp from Linear Audio
This one is a bit better. Output is just shy of 1V rms. Bandwidth is good with no funny stuff. You're gonna need some massive heatsinks though...
Ed's point is that a sim is nice, but real pieces of silicon, carbon, and copper may not give you what the sim predicts. RM's circuit performance as a real, built item is outstandingly good. Makes me want to try to do better using vacuum tubes...:D
Might not!!!??? I have some simulated amplifiers that are so close to perfect it is scary. Of course when you build them they don't come close. Then after you tweak in all the real values they still don't!
Reminds me of the internet dating beauty....
I fully realize that. So, even if it's twice as much distortion, we're still talking 0.0004%. OK, make it ten times as bad... 0.002%... big hoop dee doo.
I'm looking at peltier devices for cooling... hahaha.
You wanna do this with tubes?!?!? Your headphone amp is going to double as a space heater.
Dirk, I know that DBs work very well - already tried a simple unitary gain DB buffer (open-loop: there's more than one way to do it... :D) with CCS on input bjt emitters and CFPs on output: it rocks.
Nevertheless, I'm afraid I can't get the point. I mean: you can build the DB you simmed, measure it, listen to it and then - if it works well and _as expected_) eventually submit it to Janneman's LA. Then someone will pop up and say: Damn, why another discrete DB? Wht not a 49600? Why not a simpler power follower with an active load...? There's more than one way to do it (yeah, I'm a PERL fan...), and probably my way is different from yours or Richard's - to me electronic design is a matter of good engineering practices * and * personal taste: as long as the former are obeyed...
L.
L.
Well, that's why I will never submit it to a magazine... :D
I was just playing around. Someone mentioned the idea of doing something great with a buffer with as few transistors as possible. So, thus the gauntlet was thrown down.... at least I had the guts to rise to the challenge. What's your circuit that meets those requirements? Can you show one? Come on, I'm waiting... Do you have a SE mosfet circuit lying around that sims good? Ha, I bet Mr. Pass can come up with something fantastic with ONE transistor... HAHAHA. Me, I'm not that talented.
Disabled Account
Joined 2012
L.
BTW - the 49600 thd is very high... it must be used within the feedback loop of an op amp to get thd down. Also it cant put out great performance into 30 ohms. Note: the headphone Amplifier is not a buffer.
Disabled Account
Joined 2006
In other words you believe that simulation always shows better than real performance, obviously you havent always simulated your circuits. In many cases the real pieces of silicon perform better than simulation. This all depends on the models which in many cases are optimistic which is a sad affair but when done properly it will surprise you. Even among Bob Cordells models I find some optimistic values but its understandable in light of factory production tolerances and the time required to get these models to match the real silicon.
Sometimes the results goes the other way though.
Disabled Account
Joined 2006
Guys, we're talking about an open-loop small-power buffer capable of 0.001% THD into 30 ohm - it seems there's quite a lot of good engineering behind these figures...
L.
This is easily achieved, Im dumfounded when you make it seem likes its a miracle or something only known to a select few or something. Dirkwright has shown you the way, anything else youd like to improve on it, faster settling, less power consumption and higher efficiency or perhaps even better load handling capability, I can show you how its done if youd like.
