link
Technically black/violet goes to L rather than N, but this isn't a catastrophic mistake and your description of the transformer connection is otherwise correct.
I would suspect, therefore, that you are using a quick-blowing fuse, which will trip on the inrush currents.
You're correct on quick blow, couldn't find slow, however instructions call for 0.25 A fuse rating; think 1A slow are available. . I'll swap the b/v.
Thanks,
Warren
Richard,
I’ve finished the phono stage and power supply. AC and DC voltages through the power supply seem fine; however, there are anomalies with both of the circuit boards. Here are readings you suggest with IC3 and IC4 installed, and IC1 and IC2 not installed:
******************LEFT*******RIGHT
IN+ to IN-:************0********0
OUT+ to OUT-:*********0********0
GND to Pin 4 of IC1:****+11******+19
GND to Pin 7 of IC1:****-19******-11
V++ to V--:***********38******38
Look forward to your advice.
Thanks,
Warren
Thanks,
Warren
The X-reg section of the negative supply (left, Q2) and positive supply (right, Q1) is not functioning properly. You've probably mixed up the transistors, putting the npn BD139 in Q2 L and the pnp BD140 in Q1 R. Double check the identity and orientation of all transistors.
2 transistors installed wrong, each board had matching transistors. Dumb mistake. Apparently still have problems, h'ever. Both boards now give identical readings: g & 4 = +17; g & 7 = -11; ++ to -- = 39. Tough to pull the transistors, might have damaged parts, but both boards give same readings.
Warren
Warren
The "E" marking on the board indicates the emitter, pin 1. Q2 is oriented 180 degrees with respect to Q1.
Though I'm a bit confused because it seems like the working positive X-reg you had before has is now not working.
Problem is at any rate isolated to Q1,2 ... worst case you have to replace them, but take the time to check everything again first, they might be just the wrong way round.
Rather than worrying about the pins of IC1,2 right now, you can just measure the X-reg output at the unused V+ and V- test pads. It will be the same value.
Orientation & placement of transistors appears correct now. Original mistake was forgetting they were two separate part numbers. Reading instructions, emitter is left leg when facing printed side, legs down. Readings at (v+) - (v-) = 28 vdc.
Rember, I swapped only two transistors, would damaged parts explain this condition?
They are almost identical, the BD139 and BD135 are the same as are the BD140 and BD136.
Ronald.
Ronald.
BD135,137,139 are the npn, differing only in the voltage rating, BD136,138,140 are the equivalent pnp. All kits ship with BD135,136 pairs as Q1,2, but the schematic shows BD139,140 because that's what Eagle has as default and I didn't bother renaming.
"Rember, I swapped only two transistors, would damaged parts explain this condition?"
Not that I can see, no. The output value, or working condition of the positive X-reg will not effect the negative side, as the reference is taken off the input voltages V++ and V--.
As I understand (referenced to COM/ground) you have V+ +17V, V- -11V on one board, and V+ +17V, V- -11V on the other, and initially you had BD135 for both Q1,2 in one board and BD136 for Q1,2 in the other. The final result is that Q1 of both boards is damaged. Even if the transistors placed incorrectly are damaged, it doesn't add up.
Q1A BD135 [+11V] -> no change (correct, should give +11 V)
Q2A (BD135) [+19V] -> (BD136) (if damaged +17 V)
Q1B BD136 [-11V] -> no change (correct, should give -11 V)
Q2B (BD136) [-19V]-> (BD135) (if damaged -17 V)
Perhaps the simplest thing is for me to send you replacements...
OK, but I'm going to send you a full recap in a couple of hours from my office computer ... to be sure you know everything I did.
I think your summary is correct, but let me recap just to be sure, I’m using right and left as reference.
Background: I forgot that there were two different transistor models and treated them as all being the same. My orientation has always been: when looking at the printed side of the transistor, and the legs are pointed down, the left leg is the emitter. Based on this assumption, the orientation has always been correct.
Initially, both bd136 were installed in the left board, both bd135 were in the right board. Readings were: Left, ground to pin 4, (+11), to pin 7, (-19). Right, ground to pin 4, (+19), to pin 7, (-11).
I swapped two transistors so that there is now one of each on each board, 135 in q1, 136 in q2. Readings now are: Left, ground to pin 4, (+17), to pin 7, (-11). Right, ground to pin 4, (+17), to pin 7 (-11).
Given the three in-line legs, I found it difficult to de-solder and remove the two transistors. It took more heat, force, and time than I liked. I could easily have cooked or damaged one or both. However, the two transistors that were correct were not touched.
Based on this, if you still think it best that I replace all four, let me know.
Is it possible you made a mistake for the second set of measurements? Your report should have read, logically, for swapping Q2 of board 1 with Q1 of board 2-
"I swapped two transistors so that there is now one of each on each board, 135 in q1, 136 in q2. Readings now are: Left, ground to pin 4, (+11), to pin 7, (-17). Right, ground to pin 4, (+17), to pin 7 (-11)."
Simplest is just replace all four. I've sent you an email.
I have two 24VA (2x12VAC) printtransformers (see link)
Would these be enough for a double mono powersupply?
Printtransformator, 12-0-12, 24VA - Transformatoren - Componenten & Elektronica onderdelen
I think they will be OK but you have to use one diode bridge because the transformer does not have two seperate secondary windings. As it is not a toroid transformer you have to be more carefull you do not introduce hum.
Ronald.
PS Als je me een email stuurt kan ik het je ook in het nederlands uit leggen. gr.
Ronald.
Hi Ronald,
Thanks! The transformer has 12-0-12 secondary windings. Isn't that the same as two separate windings?
Jan
Jan
Two PSUs from two separate transformer-windings are independant of each other, 12-0-12 is like a siamese twin they always are connected to each other. I think it will not influence the sound. What will influence the sound is that they are rather small (24 VA). To start with they will be OK, you can allways upgrade later.
Ronald.
Ronald.
This only applies to To126 & 2sa/c packages.................... My orientation has always been: when looking at the printed side of the transistor, and the legs are pointed down, the left leg is the emitter...........
To220, To3p, To247 & To264 devices are the reverse of To126.
I am away to check 2sa/c.
Yes, 2s Pin out matches To126
- Analogue Source
- The Phonoclone and VSPS PCB Help Desk
