Ladies & Gentlemen - The Emken
Blimey,
Things have really moved on.
Interesting to see the graphs showing where the dips in response lay and the way cone treatment shifts things around.
Is the plugs lack of parallel section below the the cone / voice coil former causing issues?
its actually better in most respects than the standard bullet shape was. i got very little improvement from the conventional bullet shape and i had an hunch that the whizzer was just too big for it to work well. so i've flared it out at the end as i've seen in a few other classics of the full range world and the difference was very impressive.
The shape has me thinking of mounting a modified FT17 on the end of the phase plug (bolt thru the pole vent to hold it in place.
dave
Dual Concentric Eminence 12LTA? I know the tweeter is normally mounted on the same baffle as the 12LTA - I wonder if you could get it to fit at the same plane within the whizzer cone. 2 Questions:
1)Would there be time/phase issues with mounting a tweeter there?
2)Would the fact that the tweeter blocks most if not all of the whizzer's direct output be a problem?
I'll hold off letting the the FT17H into the baffle to see what you guys measure on the DC version
Will be playing with 'pluff' around the whizzer and maybe some packing noodles cut into wedges and then some polystyrene as its a bit firmer. I don't think that I'll be painting anything on the cones at the moment. Maybe enABL dots later
1/ can't be worsr than fitting it on the baffle.
2/ one should be able to make a tweeter-plug of very similar shape to gaf's. One would start by dremeling off the flat mounting part of the plastic bezel.
For this ap, a very compact horn is required and the FT17 is the most suitable i have.
dave
Formulas as I understand them - to find cap value - C = 1/(2pi)FR. R being imp. of driver. To find freq - F = (1/(2pi)R)/C
So for ft17h and 1uf cap - F = (1/(2pi)8)/1uf = 20k
Glory be it's rainin down in Texas. Not floodin but I'll take it.
