Hello Frank
Do you think these type of suspension can work well with longer tonearm like 15" or 16"? One will be 12" that sure.
Also these would be the material for arm wind guys you advised to me? You wrote I think you like it a lot these or similar material...
I do not want to buy in case these not the same, please remember I have ultra light weight titanium, 2 size carbon fibre and aluminium arrow shaft( similar to Naim wand).. All light weight and they do look promising.
Garolite XX Bakelite Tube, .500" OD x .063" Wall x 12" | eBay
Would you please let me know.
Thank you 🙂
Greetings Gabor
Thank you 🙂
Greetings Gabor
I did another few bits with the arm. The most significant thing was something I remembered frank saying a while back. I decoupled the counterweight. So it now sits on 3 o-rings very similar to how the original rega counterweight was done. The difference in this is not small.
I also made a rest so I can lock the arm when not in use. Makes it a lot safer when kids are about. Anyway I think it's time for a few pics!
I shot a short video that's up on YouTube:
VIDEO0091.3gp - YouTube
Fran
Sweet !!!! Which test LP are you using ...?
The one in the video is a cheap compilation "the rough guide to new orleans". It's actually very good sonically and musically!
Fran
Fran
Oh sorry!! Yes the HFNRR record - and I use a feickert alignment gauge to do the alignment.
Fran
Fran
Hi Gabor,
Without having tested the tubing that's offered under the ebay link, I can't say whether its's suitable or not. For armwands, I only use such a material as the outer layer of a three layer sandwich.
Generally speaking, most phenolic tubes of suitable diameter/wall thickness are not stiff enough to be used by themselves, not to mention for 16" arms.
have a great wekend,
Frank
Hi Fran,
Why did you make the headshell/armwand interface so fragile and the mounting plate so massive?
Frank
Hi Fran,
The mounting plate: basically its what I had to hand. The headshell is pretty strong - its made from a single piece of aluminium. It "feels" strong if you know what I mean.....
Fran
Fran
My Schroeder arm is almost completed. It missing only the wood wand tube. Here the pictures. It has a micrometric VTA adjuster kind like the one on the Graham tonearm. Counterweight with fine adjuster brass screw, plastic (Rulon material) sleeve insert between arm tube and counterweight for smoother adjustment and vibration control. I'll use a kevlar thread for the pivot point. The mounting hole is the same as a REGA, lifter (JL-45) from Jelco. It will need a custom slide section. The standard one is not long enough.
A new Schroeder Clone from South Africa
My Schroeder clone is 99% complete. Need to replace two screws with grub screws, File out the cart mount slots, install tonearm wire and cartridge. Then it is off to the turntable!! Please leave comments/suggestions!! Happy listening!! Ernst
Yep, make one from wood and send the rough one to me…
Just kidding, Stunning work mate, well done
Please leave comments/suggestions!! Ernst
Тoo many screws!
Regads zeoN_Rider
Hi Mr. Henning,
Congratulations; wonderful work! Would you mind giving the dimensions of the magnets you used?
Greetings, Hansrudolf
Headshell
I used previously used geometry that already had the angle worked out and used. Yes, I have space to wiggle the cartridge for setting the angle, the slots will be a wee bit wider than 2.5 mm, that should be enough... Happy listening!! Ernst
Hi Fran,How did you work out the angle for the headshell - have you any wriggle room built in?
Fran
- Analogue Source
- DIY Schroeder Tonearm?
