DC Servo MOSFET Amplifier
Hi sir apex do you have pcb on this design because i want to try build this amp..
Thank you.
regards,
nix
No, use basic pcb for drive and another pcb on heatsink for outputs.
Hi Mile,
I finished the board but I using IRF640 and 9640,
also use BC639,BC640 to instead the BF420,421
I had measure the bias just 3.4mA and the LED also not lit,
I also measure the voltage between the LED just 1.2V,
please let me know what can I do.
Thank a lot!
Q1 and Q2 are BC556, and connect input gnd to psu gnd...
This PSU and Protect circuit ca be used with any amplifier. Short-circuit protect based on Tandberg schematics is 100% efficacy.
Dear Apexaudio
greetings can this power supply be used with b500 TEF i mainly need
short circuit protect dc supply is 70 volts+/- 10 pairs 2sc5200 2sa1943 other than filter
caps what other changes are to be done or if possible can you please share any other short circuit protection which can work for this amp please can you help me
warm regards
andrew lebon
