TSSA - The Simplest Symmetrical Amplifier
I would love too be there but i cannot find space in the calendar next week. I have two orders that needs to be shipped next week. And we are running as fast as we can. Where in sweden are you located?
Probably top range models shipment, I assume only these can stop you from visiting Munich. :rolleyes:
Where did you get that, connecting me with Sweden :D I've never even visited it, although I would love to. No Sweden, Slovenia is the country of my origin, still. ;)
TSSA Basic 1.1
Sure, i just build it as is to study it. What do you think to replace the 1kOhm resistors with CCS´s ? Gives more open loop gain but stability has to be watched.
Gerhard and all interested, I finally found spare moment to make an upgrade to basic version, now with CCS integrated.
I'm sure this would measure even better than the first basic version built by Sonnya, sound quality should follow as well.
Regards, Andrej :)
Regards, Andrej :)
Few more words about TSSA Basic 1.1
- CCS pair transistor's flats should be glued together
- input pair transistor's flats should be glued together
- BF245B source-gate resistor value for Id=2 mA
- 500 ohm MT (multi turn) trimmers set output bias current (0,25-2A) and output DC offset (zero volts)
Amplifier power output 50 Wrms/4 ohm. ;)
Regards, Andrej :)
The OLG will not change much. The open loopgain is more or less set by the RC divided by the feedback resistors which are => 2K2/(36R||1K) => 2K2 / 34 => 65gg
It is multiplied by: (RLOAD/(1/gfs)).
For the exicon (10N20 and 10P20) it is: gfs = 2.5S @ ID=2.5A.
65gg x (8/(1/2.5)) => 1300gg or 62dB.
OLG 62 dB is OK. Distortion spectral profile will be much more clear than before. What do you think, will you test it? :cool:
I am not a fan of pure CLASS A (It is not ECO friendly :D ) but i will maybe test the attached version.
This way the current through the input BJT will be the same and symmetrical regardless of bias current and offset adjustment. => Every amp will sound the same way.
My current class A amp dissipates around 60-75 watts per channel with a bias of 2.5A, the previous one ran six Amps per channel. My lafet amp(2SK135 and 2SJ50) i have no clue on dissipation as its stone cold despite 150mA bias per channel.
All my other amp project run between 30-70mA bias per channel.
Sorry i did not want to Pick on you...
