Simplistic NJFET RIAA
I'm not sure. The thing is that Q1 drain on both ch. was shorting to ground
once I start tightening it to the sink. Strange that was not the case with Q4-
it stayed insulated from the sink no matter how tight it was. I know that as
my audio gnd is separated from the safety gnd by 10R-2W II 100n NPO.
My meter showed 0ohm Q1 (tightend to sink) to chassis and ~10ohm Q4 to chassis.
Huge HS. Voltage will reach 28VDC and it will stay there, the photo was taken less then a minut after switching on.
Fired up today. We have music in both channels 😀 Thank you Salas.
I only have one record at the moment. Even that's borrowed. So I'll be around the charity shops in the next few weeks and see if I can get something to compare with digital.
I will post some pics for you when I've tidied up.
There's some hum too that needs sorting.
Thanks again Salas.
I have some graphite to240 pads. I purchased them (years ago) because of their astoningshly low thermal resistance.
Unfortunaly they are conductive. It was written on the specs.. 🙄
I am so surprised how good my £12.50 Technics deck sounds. Salas, your circuit is working great. The music dept, at work is chucking out a pile of classical vinyl, which I have just inherited.
I still have a slight problem with hum. However, it seems that there are quite a few causes of it besides earth loops. I thought I would need to rehouse my RIAA circuit, but maybe not.
