Studio Reference Amplifier
I hope this one is fine
Thermal Coupled
Hi...🙂
This my PCB design of SR200,
Are all these small TR need to thermally coupled?
I arranged them like that so it easy if it is need to thermally coupled
It is still need to be check again & if it its a bad design I will redesign again...😀
Dear Apex,
I have 2 pcs of 4,7 uf Jantzen MKP, is it possible to use them instead of 10uf (C1), considering that now I use very low budget 10uf MKP. What is the result? Or should I have to find another 10uf MKP. It's hard to find good 10uf MKP in local suppliers.
I also have 2 pcs 2,2 Bennic's and 2 pcs Solen MKP and I plan to use them instead of 1uf (C4) for the same reason above.
Thank you so much.
Best Regards,
Arif B
Dear Apex,
Thank you so much.
Best Regards,
Arif B
It's possible to use 4,7uF instead 10uF in audio path, but no need to change 1uF in DC servo circuit.
Thanks for the quick reply. Unfortunately, the recommended replacements are even harder to source here ie BF471;s/871's! Can you suggest new alternates or a supplier? Maybe I should skip the SR50 and move to SR100...but I would like to start slowly,
