DC Servo MOSFET Amplifier
some redsign from my self
So that the best from beginer to make expert....... & i've build some design from mr. mile like B500 standart, B500 TEF and H900- all is hand made, but some pict can't upload here bcause bad camera....
regards😉🙂
Old F100 schematic and pcb will be redesign.
hello Apex
I am from Iran
Circuit I've made ​​you a quote.(post 122) But does not work.
PSU, but have not built the circuit.
All components installed correctly. The schematic with transistor bf420 and bf421 board printed on it is different.
In case the printed installation pieces on the board. Voice was a little boost. But with very high noise and high loudspeaker diaphragm and coil it will be hot and very hot IRFP9240 MOSFET. The power output is 17 volts.
But when the transistor base, I just installed the schematic loudspeaker diaphragm remains high and the output voltage is 45 volts
Znrhay diode circuit within a few volts and watts are they?
ZY2V7:?
ZY15:?
ZF12:?
hello Apex
I am from Iran
ZY2V7:?
ZY15:?
ZF12:?
CONNECT INPUT GND TO PSU GND...
